Old 07-07-2005, 06:29 AM
P.J. P.J. is offline
Default 1968 Camaro m22 question
Did the 1968 m22 transmitions come with a steel tag bolted on the side cover? and what number should the tag be.
Peter
suprss70
Old 07-07-2005, 08:12 PM
Lynn Lynn is online now
Default Re: 1968 Camaro m22 question
Do you have the Assembly Instruction Manual for 68? I know those tag numbers are set out in the 1969 AIM, but I don't have a 68.
Here are 1969 numbers:
3950356 is for RPO L48, L34, L35, LM1
3946797 is for RPO Z28 & L78
3946798 is for RPO M21 with Z28 and L78
3950318 is for RPO m22 with Z28 and L78
Hope this helps.
Lynn
Old 07-13-2005, 03:30 PM
thanks for the info
I do not have the 68 assemly manual yet.
Peter
Old 07-14-2005, 01:20 AM
NCGuy68 NCGuy68 is offline
Peter,
A friend has a very unmolested 68 L78 with a M22. It doesn't have a metal tag and doesn't look like its ever had a wrench on it. Best 'factory' 68 M22 I've seen in a long long time. There may be exceptions, but I don't recall ever seeing one.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 07-14-2005, 08:24 PM
thanks Craig for the info
I am still diging I will let you know what I find out
thanks
Peter
Old 07-14-2005, 09:44 PM
any chance of getting some pics for my resto projects
Peter
Old 07-15-2005, 04:51 AM
Ok I went out the back today and found my m20 muncie trany
the numbers on the trany are as follows
660 case,vin # 18w360660, assembly date P 8 E 24
it has a steel tag and the number is 3915077
so does the 68 m22 have a steel tag? and what is the number???
Peter
Old 07-15-2005, 06:01 AM
bertfam bertfam is offline
Peter,
ALL Muncie transmissions had a Part Number tag from the factory. Most have been lost over the years with rebuilds and what-nots, but if you still have yours, feel lucky!
The original part number for the 1968 M22 was dependant on a few things. First was when it was made. Early 68's had different part numbers than later 68's. It also depended on the rear end ratio. Here's what I have for the 1968 Model Year: (Also note that the M22 was available only on the Z28, L78 or L89 cars...)
Early 68 with 3.31 or 3.07 Posi rear end used the 3919397, which was replaced mid year with the 3932259.
Early 68 with all other ratios EXCEPT the 4.10 used the 3925626, which was replaced mid year with the 3932258. (I have no info on what M22 was used on the 4.10 and why it was different. Sorry...)
I'm not sure of the exact dates of the part number changes, but I believe it was in early 68.
Hope this helps...
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
Old 07-15-2005, 06:23 PM
ed
My car was built 04 of jan /68
375 hp L78 with 488 gears ordered
m22.
Peter???
Old 07-15-2005, 10:22 PM
Peter,
Are you asking another question or just trying to remember your name!
Ed
Ed Bertrand
1968 RS/SS L-89
396/375 Convertible
CRG Member
