Old 06-01-2012, 01:23 AM
IM RARE IM RARE is offline
Default Re: Next Years Power Tour Car
It was great see the car all dirty today thats what its all about build them and drive and enjoy them the look on your face with two thumbs up was priceless now lets go have some fun great Job on the car wouldn't expect anything else from you o yea with all the stuff my wife takes the Javelins trunk is useless see ya in the morning
Old 06-01-2012, 02:48 AM
dontlifttoshift dontlifttoshift is offline
Ken,
Thanks for plugging the shop! Happy customers are better than billboards.
Donny
Support your local hot rod shop!
Old 06-03-2012, 01:00 PM
lowmile lowmile is offline
Ken, it only took you 312 days put on that coat of wax.
Old 06-10-2012, 09:40 PM
kwhizz kwhizz is offline
8 Days, 2829 miles, with only two little issues........(1).....I changed the gas tank sending unit before we left because I wasn't smart enough to think the issue thru......I was concerned that the amount of gas that I was putting in the tank wasn't in relation to what the Dakota Digital gauge was reading.....It stayed on 99% for a very long time and when it would finally go down to say 80-90%.....I would put in 8-10 gallons........So, I assumed there was a Ohm issue....did some testing and it didn't make sense, so I changed out the unit with a repro one.....I checked the Ohm readings prior to installation and it checked out O.K........so I put it in........same results......
During the ride home yesterday I was able to take some time to think things thru and all of a sudden it dawns on me that I needed the extra room at the front of the tank for the GTO Fuel Pump
assy and made the tapered spacers to shim the tank down at an angle to give me the room I needed for clearance.....Duhhh!!.......makes perfect sense why the readings are what they are.....LOL
2nd issue.....the car didn't use a drop of oil thruout the trip....when I get home last night and unload the car......I noticed oil droplets on the rear of the car and bumper....I check the oil and I'm a quart down.....put the car on the lift today and I notice the oil pressure adapter for the sender that we made at the shop had a slight crack in it at the fitting and was leaking oil all over the bottom of the car.......small issue but a big mess on the exhaust system....burnt on oil....Yuck!!........I'll make a new one tomorrow out of a solid piece of aluminum......I used 1/2" round and welded it to the stock GM piece but after tapping the pipe thread it was pretty thin and cracked there.....Lucky it happened at the end of the trip.....
Other than that the car drove like a Dream without issues at all......and that Big trunk was a blessing......LOL
Here's the Culprit.......
Old 06-10-2012, 10:05 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body"> Other than that the car drove like a Dream without issues at all. </div></div>
No one doubted it. You have built some pretty awesome cars in the years I have known you and you are pretty good with some metal fab machines which doesn't hurt. [img]<<GRAEMLIN_URL>>/wink.gif[/img] It just goes to show you that people can do what they put their mind to. Great job Ken and kudos to Paulette for giving you the allowance to do your builds.
Old 06-11-2012, 02:41 AM
Amen!
Glad that you had fun and are home...safe!
Old 07-07-2012, 05:44 PM
Update!!........Well....The &quot;Old&quot; Beater has held up pretty well since the Power Tour ended.......But.....Here's what happened since then................The Big issue was that I had to send the car back to the Body shop to fix one of my screw-ups.....Since I had to replace the front fenders on my &quot;Perfect&quot; Survivor car, they didn't have the holes in them for the front fender trim.....so....when I got ready to install and drill the holes.......I put tape on the fenders so I didn't have to worry about scratching the paint and I marked the width of the trim right on the tape so I could easily drill the mounting holes......
Seemed like a good plan at the time......so.......I get the holes drilled, pulled the tape off, installed the trim ............and after looking at the trim installed, my stomach dropped and I was ready to puke.......I assumed that the fender spear would just be installed......Wrong!!!......The fender spear is straight and the fender reveal has a curve to it and the trim is supposed to follow the profile of the reveal in the fender........Ouch!!........I called the Body shop and because of being short on time for the Power Tour they needed the car for at least 4 days to weld the holes , Prep and repaint the fenders......didn't have the time so I said I would get it done when we got home.......fortunately......if anyone noticed the screw up on the Power Tour they were nice enough to not say anything about them.....LOL.....
As soon as we got home the car went right back to the Body Shop to be repaired.......$$$$$$$$Stupid Mistake.....But the Trim is now installed like GM wanted them to be.......
I also took the Door Panels off and added the decorative trim pieces that I mistakenly thought would have been included on fully assembled door panels as bought......LOL....again...didn't have the time to order and install them prior to leaving......but....they are now installed....
I also got sick of looking at the engine without an engine cover......I had a Camaro engine cover I was going to use but it ended up being too short....so I got some Corvette covers and trimmed them to fit.....
I also took off the Ridetech rear Panhard bar as it had spherical rod ends on it and it rattled....so In took it off and put the stock rubber bushed GM one back on.......Noise gone....and the stock one dropped right in.....
Great car......If I had to change one thing about the car I think I would put some quieter mufflers on it as the 50 series Flowmasters witgh the long tailpipes just seem a little to &quot;Rappy&quot; for me.......
Old 07-07-2012, 06:25 PM
Go with &quot;Walkers&quot; next time [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 07-07-2012, 10:14 PM
napa68's Avatar
napa68 napa68 is offline
I was going to say something about the molding on Wednesday but I did not want to be that guy [img]<<GRAEMLIN_URL>>/Can-I-Have-It.gif[/img] Ken....................your car is stupid nice!
Old 07-14-2012, 06:24 PM
Since the Power Tour is over we don't hear about this sled anymore...is it still running [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
Nu-Yawk Guy
