Old 12-06-2018, 12:48 PM
Originally Posted by Kurt S View Post
Did you coat the brake calipers and steering box with anything?
They look good.
Cosmoline
Old 12-06-2018, 12:53 PM
Originally Posted by Postsedan View Post
Slob44's pictures are just as I described to you earlier today
100% correct
You did but our car does not have gauges so this is not the right one per Solb44's photo, correct? Also, the original engine block was found with this angled fitting still in it albeit angled wrong.
Old 12-06-2018, 12:57 PM
Originally Posted by JoeC View Post
1969 Chevelle Assembly manual page 148 shows the plastic vent as "tank-fuel vent surge" My 1969 Assembly manual only shows the set up with the plastic vent. I'm not sure if there was a late design change or something not shown in the 69 manual?
We are not sure of the changeover or plant variance either but I have had a few people send me photos of their survivor cars showing the hoses and special clamp without the vent exactly like our car is so there was obviously two different designs at one time. I will be restoring the car exactly how it was found at 19,000 miles.
Old 12-06-2018, 01:03 PM
mockingbird812's Avatar
Originally Posted by SS427 View Post
Sam, which email did you send them to? I Never got those but thanks for sharing.
Rick
I did not send them directly to you - If I recall I forwarded them to you via Woj. If I recall Woj's words exactly: "I will be the clearing house for all technical information on this Nelson project?" ...or something to that effect! ;>))
Sam...
Old 12-06-2018, 01:08 PM
ah ha. Got them but seems to me they were a slightly different photo. Thanks for sending them regardless. Everyone who has been helping me with this project is much appreciated. I think I am wearing out my welcome with Phil though. He has been great and am about ready to make the 10 hour drive to go over his car. I tried doing it at MCACN but that was a wasted effort as I was only able to ever see 5 cars in two days.
Old 12-06-2018, 01:10 PM
JoeC JoeC is offline
did your car have the Yenko installed SW gauges - oil amp watertemp?
there would be holes for the gauge panel and holes in the firewall to run the lines.
I don't think Yenko used the oil pres sending unit when the SW gauges were installed
Old 12-06-2018, 01:19 PM
Chad's Yenko was equipped with the aftermarket gauges so he had the plastic line (as seen in the upper left corner of the photo). Unfortunately my photo from that time is lousy and does not show the fitting at the block. Our car had no extra gauges other than the pedestal tach. The only holes in out gauge panel were for the tach. It is odd how our fitting was turned down though the engine had been worked on so who knows.
Old 12-06-2018, 02:36 PM
ScottG's Avatar
ScottG ScottG is offline
Rick, the body and paint are excellent so far. Your suspension and chassis work is very high level also. That is going to be an outstanding car!
1971 Boss 351 , 17,000 miles .. 1971 Buick GS455 .. 2003 SVT Cobra .. 1971 GTO .. 1969 Camaro Fathom Green .. 1969 Camaro Hugger Orange .. 1970 Buick GS455 .. 1970 BUICK GS350 .. 1998 SVT Cobra 1900 miles;. 1973 STAGE 1 GS . 1971 Mach 1 351C 4 speed , first car. 1970 Mach 1 428 SCJ . 1970 SS 350 Camaro . 1971 442 ... 1968 Buick GS400 . 2015 Lexus IS 350 F Sport 2021 Badlands Bronco Sport
Old 12-06-2018, 03:13 PM
Woj's Avatar
Woj Woj is offline
Mine has the plastic gas tank vent
I only have a 1969 Assembly manual so I'm not sure about other years. It only shows the set up with the plastic vent.
My 4A Baltimore built 69 Chevelle SS survivor has the exact same vent set up as Rick’s car does. I’ll post a picture if I can resize it. Rick also has the photo if he wants to post it.
I have a January built Baltimore 69 SS Chevelle that only has the tubes as well. It was restored 30 years ago. Has the same bracket as Rick’s.
Phil W.
Old 12-06-2018, 03:23 PM
Here they are. Note that both Phil's and our hoses are too long to even get a vent on. These are the original ribbed hoses and not replacement. The bracket will also not fit the vent at least when I tried with my bracket and a repop vent. I also posted a picture of Grady Birch's car WITH the vent.
