Old 05-12-2015, 02:19 PM
68l30's Avatar
68l30 68l30 is offline
Default Re: Well, the Chevelle is D.O.A.....
The part that confuses me...it came apart under no real load. At what RPM would this have failed on the ground with traction /weight and increase friction-resistance in the driveline ? It could have been much worse. How much depth was in the yoke engagement, how did it slip under rotation? Could there have been a bind adding stress to the shaft during torque / suspension cycling? Any clues on what's left of the Muncie or the shaft (tubing, wall thickness, cracks) itself?
I enjoy doing Destructive & NDT testing on Welded-Fabricated components here at work....I find all failures interesting as they each tell a story. I'm looking forward to seeing this back together !
BIG
Old 05-12-2015, 03:14 PM
earntaz earntaz is offline
NDI to the nth ...
Old 05-12-2015, 03:17 PM
VintageMusclecar's Avatar
NDI? [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Old 05-12-2015, 03:23 PM
Nondestructive Inspection ... system used for inspection of various aircraft related componenents.
Old 05-12-2015, 07:04 PM
68l30's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Nondestructive Inspection ... system used for inspection of various aircraft related componenents. </div></div>
Yep, same as NDE.....I spend all day staring at Welds and Fabrications. I'm the guy that drives everyone nutz...... [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
BIG
Old 05-12-2015, 03:30 PM
Ah...I'm familiar with NDT, but I'd not heard of NDI. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 05-12-2015, 04:57 PM
Trans has been ordered and is supposed to be here Friday or Monday.
Old 05-12-2015, 10:51 PM
VaChevyman VaChevyman is offline
I was readin' some of the remarks here and was wondering what kind of transmission you were getting. Also wanted to say, I have a close friend restoring his LS6 1970 Chevelle to near new original except he had been racing it with an auto trans where it originally had a 4 speed, he sold the 4 speed a few years after buying it in favor of the auto for drag racing, that said, he's pretty good about researching stuff before he buys and has recently received a 4 speed built to m22 specs from a company called Auto Gear in New York. Its supposed to be even better than a m22 for quality of the gears and other parts in it. Just wanted to let you know about it in case you hadn't already heard of them. I'm a newbie and still learning at 66 years old so if I'm off base, just let me know.
http://www.autogear.net/
Old 05-12-2015, 08:54 PM
You'd think I would've known that acronym since I worked in the aerospace industry...probably knew it at one point and forgot. [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
The ol' gray matter just ain't what it used to be. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
Old 05-15-2015, 01:20 AM
wagonman wagonman is offline
Don't fret, in the Aerospace industry NDT is an acronym for both Testing and Inspection.
You don't really hear the acronym NDI To often.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: VintageMusclecar</div><div class="ubbcode-body">You'd think I would've known that acronym since I worked in the aerospace industry...probably knew it at one point and forgot. [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
The ol' gray matter just ain't what it used to be. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img] </div></div>
1969 rs/ss 396 350hp/4spd conv
1968 Z/28 crossram- j/l8 conv
1963 nova ss 350/4spd conv
