Old 06-05-2014, 04:16 PM
Woj's Avatar
Woj Woj is offline
Default Re: Field find
Wow. This is good stuff.
Starrider, does your car have any of the original drive train components? If it has the original BE rear, what is the date?
This NCRS data is proving to be very interesting.
Phil Woj.
Old 06-05-2014, 05:25 PM
starrider starrider is offline
No signs of having a Chas Carter emblem. I looked on the inside of the tail panel to see if there were any previously drilled holes and appeared never to have had any. It has original engine and trans but the rearend was replaced. Still working on trying to locate it. I spoke to the owner at the time and he replaced it because the gearing was to low. Unfortunately instead of changing the gears, he swapped it for a 10 bolt.
Old 06-06-2014, 12:39 AM
Mine was found near Moody Texas. It has been around Moody since it was about a year old with 2800 miles. I guess Moody is near Bonham.
Old 06-06-2014, 12:59 AM
black69 black69 is offline
that's such a cool car charley! I dont remember seeing an RS copo other that the blue white top ZL1.
Old 06-08-2014, 03:23 AM
Please post a pic if you have it. I have two holes on my tail panel.
Old 06-08-2014, 06:15 PM
mbxlesney mbxlesney is offline
I think these were pegged from the company that made them as you can see the rear pic where the double back tape is. I can get the measurements if need be. This emblem is in good shape but I would rechrome for a COPO show car. Later Kim
Kim
1970 Nova Fathom Blue L78 M21 3:55
1970 Nova Classic White 454HO THM400 4:10
Old 06-08-2014, 07:54 PM
I think my holes are 4 1/4 apart. Can you measure ?
Old 06-08-2014, 11:50 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Charley Lillard</div><div class="ubbcode-body">I think my holes are 4 1/4 apart. Can you measure ? </div></div>
That's what she said.
Old 06-09-2014, 03:53 AM
Hey Charley...I will check them in the Monday and let you know.
Kim
Old 06-09-2014, 05:02 PM
Hey Charley....The embossed area where the pegs would have been is 5-1/4&quot;. The emblem is 5-3/4&quot; long and 1&quot; tall on the narrow ends and 1-3/4&quot; tall on the center bulge. This emblem came off a an early 70s Caprice that ended up in a Phoenix wrecking yard in the middle 80s
Kim
