Old 12-07-2015, 04:43 PM
JpMotorsports JpMotorsports is offline
Send a message via Yahoo to JpMotorsports
I believe inline tube sell those pads as well. They are down the street from my house
1982 Pontiac Grand Prix- Dove Gray (Turbo LS swap in the works!)
1967 Chevelle SS396- Tuxedo Black- SOLD
1972 Oldsmobile 442 W29 Convertible- Sunfire Yellow- SOLD
1969 Chevrolet Chevelle/Malibu- Dover White- SOLD
1986 Oldsmobile Cutlass Supreme- Silver- SOLD
1987 Chevrolet Monte Carlo SS- Maroon- STOLEN
Old 12-07-2015, 11:12 PM
Ryan1969Chevelle's Avatar
Dan and I both had the same contact to get a perfect gas tank pad.
70Post Patton Glade on Classic Oldsmobile.
http://classicoldsmobile.com/forums/...tion-item.html
Patton has been jumping in on my thread from time to time and we got to meet briefly at MCACN so I am excited to buy one of his gas tank pads to say thanks for the support!!!!!!
Ryan
Old 12-08-2015, 01:42 AM
wheelhop wheelhop is offline
Glad to see you are finally taking this thing apart.
Old 12-08-2015, 02:05 PM
Getting prepared for Sat:-)
Stopped by last night to test fit a few lifting brackets to simplify the rigging. Need to pack up two engine hoists, shackles, straps, etc.
A few of the pictures show the wood blocking between the frame and the body, a few gas tank pictures, and a few showing the floor pan and frame.
Ryan
Old 12-08-2015, 05:14 PM
making more progress great to see!
Old 12-08-2015, 06:58 PM
The Dude The Dude is offline
Removing all the interior, glass and doors would make your task a lot easier. The lighter the body the better. That way you can lift it by the trunk latch brace in the rear and by the top two fender bolt holes on the top of the cowl. That way requires two cherry pickers. You also can use the seat belt bolt holes from the interior, which only requires one cherry picker. Either way, you need to have the body as light as possible.
Old 12-08-2015, 09:36 PM
Canuck's Avatar
Canuck Canuck is offline
I removed my convertible body years ago by pulling the rear up first, using the seat belt anchors. Then lifting the front using the front body mounts. Only one cherry picker needed.
www.vancouverclassiccars.com
Old 12-11-2015, 12:40 PM
stritestoration stritestoration is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Canuck</div><div class="ubbcode-body">I removed my convertible body years ago by pulling the rear up first, using the seat belt anchors. Then lifting the front using the front body mounts. Only one cherry picker needed. </div></div> X2. I have used 4 chains (or 2 long ones) In a criss cross pattern attatched to the rear seat belt mounts and there are two holes suitable for lifting by the kick panel area. put the engine hoist in the middle and lift. the car will be a tad back heavy but with a buddy or two they can lift and guide the chassis out of the way. I'd hate to see the body sway on you and make those firewall brackets distort anything.
Old 12-08-2015, 11:36 PM
Thanks for the words of wisdom!!
I will combine these nuggets with the plan we have if she doesn't want to go vertical:-)
&quot;Team Weaver&quot; all headed out full of piss and vinegar tonight to buy a parts car, 1969 Oldsmobile Cutlass S Convertible. Gold, gold, white top, 350 column auto.
We are returning empty handed, what a steaming pipe of s##t!!!
Seller honestly felt a lot of the car was usable, but he is incorrect:-(
Wasted some money tonight but some time spent together is ok by me:-)
I don't stay mad long:-)
Now let's get some dinner!!!!
Ryan
Old 12-08-2015, 11:41 PM
DW31S's Avatar
DW31S DW31S is offline
What do you need that you'd get off a parts car???
