Old 02-27-2026, 06:54 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Originally Posted by RPOLS3 View Post
Thanks - I am hoping the driver's side will turn out just as nice.....
On a chance I stopped by the upholstery shop today and as luck would have it they just finished the driver's seat..............so I was able to get it cleaned and installed. I think it turned out great.
Also picked up a fuse and a courtesy light bulb as when tinkering with that last night some sparks flew........all good now and can check the box on that task.
Looks like a need a high beam switch grommet for the carpet.......
Jake Dykstra
Dykstra Motorsports
The Following 15 Users Say Thank You to RPOLS3 For This Useful Post:
1967 4K (02-27-2026), 60sStuff (02-27-2026), 67since67 (02-27-2026), 69M22Z (02-27-2026), big gear head (02-28-2026), carnut4life (02-27-2026), cheveslakr (02-27-2026), dykstra (02-28-2026), juliosz (03-02-2026), L78_Nova (02-27-2026), olredalert (02-28-2026), PeteLeathersac (02-28-2026), Tenney (03-01-2026), Woodrock (02-28-2026), Z282NV (03-01-2026)
  #72
Old 02-27-2026, 07:11 PM
napa68's Avatar
napa68 napa68 is online now
Jake, you and Tim S are making the rest of us look like slackers!! Great work!!
Jake is making us ALL look bad. Keep in mind, he still has a full time business plus knocking the cars out
The Following 11 Users Say Thank You to napa68 For This Useful Post:
67since67 (02-27-2026), 69M22Z (02-27-2026), dykstra (02-28-2026), juliosz (03-02-2026), L78_Nova (02-27-2026), markjohnson (02-28-2026), olredalert (02-28-2026), PeteLeathersac (02-28-2026), RPOLS3 (02-27-2026), Tenney (03-01-2026), Z282NV (03-01-2026)
  #73
Old 02-28-2026, 09:09 PM
olredalert olredalert is online now
----Stop looking for a dimmer grommet. Don't think I have your address but when you get it to me I'll send it off.....Bill S
The Following 4 Users Say Thank You to olredalert For This Useful Post:
dykstra (02-28-2026), PeteLeathersac (03-02-2026), RPOLS3 (03-01-2026), Tenney (03-01-2026)
  #74
Old 03-01-2026, 04:22 PM
RPOLS3's Avatar
Thanks Bill - appreciate it. PM sent
Jake Dykstra
Dykstra Motorsports
The Following User Says Thank You to RPOLS3 For This Useful Post:
olredalert (03-01-2026)
  #75
Old 03-02-2026, 12:06 AM
RPOLS3's Avatar
I was able to spend a couple hours pecking away at things this afternoon......
First up was swapping out the headlight motor switch. I had to loosen up and scoot out the cluster just enough to slide out the switch - if anyone else knows a better way to do this I'm all ears. Switch is installed and works, but after a couple rounds of testing the noisy passenger side headlight motor sh*t the bed and remains in the open position. Based on the look of the motors they have been restored/repaired at some point as they are pretty clean relative to their surroundings. Two steps forward and one step back seems to be my theme when working on these old cars............
Next were some coolant related issues. After discussions with the seller - he was unsure about the last time the coolant was changed so I wanted to at least drain and refill the radiator. While the radiator was drained I swapped out the temperature sending unit (measured the resistance of the new vs. old units and they were VERY diffrerent) and that solved my temperature gauge problem, then I swapped out the heater control valve hoping that would solve my no heat problem. The repro unit the parts houses sell doesn't look a thing like the original and doesn't even fit in the bracket (I'm assuming the unit on the car was an original). The valve on the car seemed to be stuck shut and this was confirmed after I removed it. I was worried the heater core was either plugged or full of rusty coolant since it seems the valve wasn't allowing flow through the heater core. I flushed the heater core with distilled water and nice clean green coolant came out - no rust. The drained coolant from the radiator appeared really fresh too, so that is good. I put all new distilled water and anti-freeze back in it anyways. While the fluid was out I swapped out an incorrect worm type lower hose clamp at the radiator to a more correct tower clamp too. Still no heat, so thinking the vacuum line that activates the valve might be disconnected somewhere under the dash.......always something - but making progress. Maybe if that is the case and I can loosen up the original heater control valve it will get re-installed. Good news is that when I started the car up the choke/high idle worked and there appears to be no coolant leaks. The temperature guage went up until the thermostat opened and then came down and pretty closely matched the temperature of the heat gun indicated temperature on the themostat housing.
So now to dig into the dash to hopefully find the potential vacuum leak (maybe remove the windshield wiper motor while I'm there) and then maybe get out the headlight motors........next weekend's tasks.
Jake Dykstra
Dykstra Motorsports
The Following 12 Users Say Thank You to RPOLS3 For This Useful Post:
67since67 (03-02-2026), 69M22Z (03-02-2026), big gear head (03-02-2026), carnut4life (03-02-2026), dykstra (03-02-2026), juliosz (03-02-2026), L78_Nova (03-02-2026), napa68 (03-02-2026), olredalert (03-02-2026), PeteLeathersac (03-02-2026), Tenney (03-02-2026), Z282NV (03-02-2026)
  #76
Old 03-02-2026, 12:07 AM
dykstra's Avatar
dykstra dykstra is offline
Lookin great!!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
RPOLS3 (03-02-2026)
  #77
Old 03-02-2026, 04:31 AM
Z282NV's Avatar
Z282NV Z282NV is offline
Step by step Jake. Looking at the third picture, even the Corvette is winking at you.
Joe
1969 Camaro
The Following User Says Thank You to Z282NV For This Useful Post:
RPOLS3 (03-02-2026)
  #78
Old 03-02-2026, 10:39 AM
dykstra's Avatar
Mid-year Corvettes are just good for the soul! Dad is smiling down for sure.
Dave Dykstra
NCRS#66003
Dykstra Motorsports
The Following 6 Users Say Thank You to dykstra For This Useful Post:
69M22Z (03-02-2026), napa68 (03-02-2026), olredalert (03-02-2026), RPOLS3 (03-02-2026), Steve Shauger (03-02-2026), Tenney (03-02-2026)
  #79
Old 03-02-2026, 10:54 AM
69M22Z 69M22Z is offline
Amen!!!!
The Following 3 Users Say Thank You to 69M22Z For This Useful Post:
dykstra (03-02-2026), napa68 (03-02-2026), RPOLS3 (03-02-2026)
  #80
Old 03-02-2026, 08:34 PM
----Jake,,,As far as heater operation goes, you should know that Florida Corvettes and other FL cars are famous for having a plug in the in line to the heater core to keep any heat coming in to the interior. This was also done to cars when the core shit the bed. If there, it would be somewhere on the in to the core hose most likely, and close to an end. You would be able to see it when the hoses are off, or if you're lucky, you mat be able to feel a lump in one of the hose ends....Bill S
RPOLS3 (03-03-2026)
