Old 06-04-2014, 08:37 PM
Default Re: Field find
Why do some reports have the name of the dealer and others don't, sometimes with the same codes????
Old 06-05-2014, 02:33 AM
That's cool...two from the same date....from the same dealer!
Old 06-05-2014, 02:46 AM
PeteLeathersac's Avatar
191 Vins apart, how close are the body #'s?
[img]<<GRAEMLIN_URL>>/naughty.gif[/img]
~ Pete
Old 06-05-2014, 12:46 PM
starrider starrider is offline
Old 06-05-2014, 01:02 PM
68l30's Avatar
68l30 68l30 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PeteLeathersac</div><div class="ubbcode-body">
~ Pete </div></div>
I'd say the body numbers are as close as it gets! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
BIG
Old 06-05-2014, 01:20 PM
Wow starider...you two are only one number away on Fisher body numbers.
Charleys
Old 06-05-2014, 01:51 PM
starrider do you have a Chas Carter emblem on the back of your car ? Holes for one ?
Old 06-05-2014, 03:16 PM
Woj's Avatar
Woj Woj is offline
Wow. This is good stuff.
Starrider, does your car have any of the original drive train components? If it has the original BE rear, what is the date?
This NCRS data is proving to be very interesting.
Phil Woj.
Old 06-05-2014, 04:25 PM
No signs of having a Chas Carter emblem. I looked on the inside of the tail panel to see if there were any previously drilled holes and appeared never to have had any. It has original engine and trans but the rearend was replaced. Still working on trying to locate it. I spoke to the owner at the time and he replaced it because the gearing was to low. Unfortunately instead of changing the gears, he swapped it for a 10 bolt.
Old 06-05-2014, 11:39 PM
Mine was found near Moody Texas. It has been around Moody since it was about a year old with 2800 miles. I guess Moody is near Bonham.
