Old 06-26-2013, 10:37 AM
m22mike's Avatar
m22mike m22mike is offline
Default Re: 1969 Malibu
Rick, as much as I would love to have a car there in the winter it is just not possible for me. Thanks anyway.
Mike
Old 06-29-2013, 06:34 PM
wheelhop wheelhop is offline
Mike, looking forward to seeing you and your car in Ohio in a month!
Old 07-07-2013, 11:23 PM
slammed1 slammed1 is offline
Great looking car,looks real nice now with the colored top.
A friend of mine here has a 69 Malibu that came Burnished brown with a cream white painted top,black vinyl interior,12 bolt,th350,327,and frt disc brakes. I will be sending him a picture of yours.
just a gearhead
1966 Belair sleeper
Old 08-22-2015, 04:16 PM
m22mike's Avatar
I spent last winter working on my 89,000 mi. Malibu and doing some much need mechanical upgrades plus detailing the crap out of the engine bay so I don't through up when I open the hood.
So I accomplished what I set out to do with this car, and that is to once again prove you can not bring a very nice low buck car 100% up to speed and come out ahead $ wise, I might be a little upside down in her but what a great driver now, the Malibu is not going away anytime soon. I have only had the Camaro out once the year.
I added up receipts to date and I am north of 7000 bux, and that's just parts and no labor. And the 350 short block was donated by my son. Yet to come are headers and exhaust and I should be done.
Here is some of the major stuff.
AC....new condenser, dryer, expansion valve, 2 aluminum hard lines and both rubber line assemblies, and a rebuilt compressor. POA valve calibrated/tested. Yet to be serviced, with R12
Suspension....New Moog springs, all bushing front and rear, new lower ball joints, added rear sway bar and I boxed the rear control arms, added a GM 12 bolt with a GM 3.31 post and new Moser street axels, all new bearings and seals . The OE tie rod ends and upper ball joint were very serviceable. The 3.31 posi was a gift form a buddy, he was given this unit in 69 that a friend took off a new SS Chevelle that he raced.
Brakes....Added GM front disc brakes, rebuilt front and rear brake cylinders and front calipers, restored the GM brake booster and plated in cyanide cad, rebuilt the round hold off valve, added all new hard lines and rubber lines. Flushed and service with DOT 5.
Drive train/ engine bay...Removed the 307 and installed a fresh 9.5:1 cr 355 sbc with new Dart heads, a 650 Vac sec Holly, Crane hydraulic flat tappet cam, resealed the OE TH 350, and new U joints. Rebuilt the PS pump and PS gearbox, and replaced the 2 PS hose assemblies. Disassembled cleaned and repaired the steering column. It only needed a new ignition sector gear and a tension spring for the key warning buzzer contact. Rebuilt the wiper motor, replaced a damaged gear and installed a NOS terminal board that had a broken dropping resistor. Rebuilt the starter and the alternator.
Added the correct 350 engine stands with new motor mounts.
Some before pic's
Original 307 motor mounts, I think they were done.
A special thank you to Eric Jackson for the great job he did in providing me with allot of tech help and direction in choosing the heads, cam, rockers, pushrods and head bolts, etc.
And the great Holly 650 he put together for me at a very reasonable cost, it performs perfect.
Old 08-22-2015, 04:30 PM
m22mike's Avatar
Eric's handy work [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 08-22-2015, 04:49 PM
m22mike's Avatar
Here are some pic's as the car sits now with the new springs. You will notice the car had Cragers with Goodyear Eagle GT II's on it before. P235 60 15 front and P255 60 15 rear. Last Tuesday coming home from a cruise in I had a right front tire go flat on I271 [img]<<GRAEMLIN_URL>>/mad.gif[/img] 3 hrs. later I get home on a flatbed, minus 125 bux... [img]<<GRAEMLIN_URL>>/mad.gif[/img]
Next morning I took off the flat and aired it up, split valve stem... [img]<<GRAEMLIN_URL>>/mad.gif[/img]
So The newer picture are with the SS 5 spokes wheels I once had on my Camaro with D Back redline P215 70 14's. The Chevelle needs a little more tire on it, but I may stick with the SS wheels and invest (ouch) in another set of redline tires.
Old springs
New springs
And my latest 69 Plate.
Old 08-22-2015, 04:53 PM
scuncio's Avatar
scuncio scuncio is offline
Nice looking car Mike.
Old 08-22-2015, 05:31 PM
earntaz earntaz is offline
I noticed the vac advance is connected to the baseplate and not the timed port on the metering block. Does it idle OK without a &quot;shake&quot;. I just redid a 69' 3310 which did not have a timed port -- had to get creative with the drill to establish a timed port on the RH side of front metering block. TAZ
Old 08-22-2015, 05:39 PM
PxTx's Avatar
PxTx PxTx is offline
The car is configured the way it is supposed to be.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">I noticed the vac advance is connected to the baseplate and not the timed port on the metering block. Does it idle OK without a &quot;shake&quot;. I just redid a 69' 3310 which did not have a timed port -- had to get creative with the drill to establish a timed port on the RH side of front metering block. TAZ </div></div>
Paul III
Old 08-22-2015, 06:36 PM
m22mike's Avatar
I actually tried it both ways, it idles and runs VG using full ported vacuum.
I went with a VC1810 (B28) can. 8* distributer/16* crank. fully deployed at 8hg. Starts coming in around 5 HG. Tried it with ported vacuum and still did not act right.It was surging some because of the weaker vacuum signal, Switched to full manifold vacuum and now it is stable @ idle and I have just shy of 18hg.
I don't think I will change a thing, idles very smooth and throttle response is great.
I posted this link just recently in another thread, it is a good read, great info on vac advance and how it should work.
Vacuum advance cans
