Old 02-07-2009, 10:33 PM
1969grb 1969grb is offline
Default Re: lift hooks
The orange paint on the bracket appears to be spatter from when the engine was painted when new. At least that what it looks like to me.
Grady
Old 02-07-2009, 11:14 PM
Steve Shauger's Avatar
Administrator
Here is another unpainted.
www.vintagecertification.com
Old 02-08-2009, 01:03 AM
mockingbird812's Avatar
And the final tallies are in:
50 for and 50 against.........
You be the judge!!
Sam...
Old 02-08-2009, 01:23 AM
sg1747 sg1747 is offline
Component
Camaro Nationals Seminar
MacNeish Book
AIR adjusting brace: Semi-gloss black Black paint, 60 percent gloss
AIR anti-backfire valves: Gold cadium Gold cadium dichromate
AIR pump support brace: Chevrolet orange paint Chevrolet orange paint
AIR pump bolt: Phosphate (not specified)
AIR smog pump housing: Natural aluminum finish Natural aluminum finish
AIR smog pump pulley: Phosphate Semi-gloss black paint or gray phosphate
AIR smog tubes: Black zinc Semi-gloss black paint or gold cadium dichromate
Air cleaner base, open element: gloss black 60 percent gloss black paint
Air cleaner lid, standard open element: Chrome Chrome
Air cleaner stud: Silver cadium (not specified)
Alternator assembly: Natural aluminum finish Natural aluminum finish
Alternator pulley: Silver cadium Silver cadium dichromate
Alternator fan, 1967 Z/28: Semi-gloss black paint Semi-gloss black paint
Alternator bolt, lower: Phosphate (not specified)
Alternator bolt, upper adjusting: Silver radium with special extra thick washer (not specified)
Alternator Brackets, lower/upper: Semi-gloss black orange (not specified)
Alternator brackets, lower (not specified) 60 percent gloss black paint
Alternator brackets, upper (not specified) 60 percent gloss black paint
Alternator brackets, rear: (not specified) Chevrolet orange paint
Alternator bracket spacer: Semi-gloss black or natural 30-60 percent gloss black paint
Battery hold-down clamp: Phosphate Natural metal finish
Battery tray: Semi-gloss black 30 percent gloss black paint
Bell housing: Natural with orange over-spray Chevrolet orange paint
Bell crank, throttle linkage: (not specified) 30 percent gloss black paint
Brake hose bracket: (not specified) Natural metal or silver cadium dichromate
Brake lines: (not specified) Natural metal finish, stainless steel acceptable
Brake switch/manifold: (not specified) Natural metal finish
Bumper brackets, front and rear: (not specified) 60 percent gloss black paint
Bumper jack base: (not specified) Semi-gloss gray paint
Bumper jack adapter: (not specified) Semi-gloss gray paint
Bumper jack mechanism: (not specified) Semi-gloss gray paint
Bumper jack pole: (not specified) Gold or silver cadium dichromate
By-pass elbow (water pump 67-68 302): (not specified) Silver or gold cadium dichromate acceptable
Carburetor body: Gold dichromate Gold cadium dichromate
Carburetor lever and arms: Gold cadium on Holley (not specified)
Clutch fork: Natural metal finish Natural metal finish
Clutch linkage: Phosphate Semi-gloss black paint or natural finish acceptable
Coil bracket: Silver cadium Silver cadium dichromate
Coil: gloss black (not specified)
Coil bracket mounting bolts: Silver cadium (not specified)
Column locking mechanism: (not specified) 30 percent gloss black paint
Control arms, front, upper and lower: Semi-gloss black 30 percent gloss black paint
Control arms, mounting bolts: Phosphate with silver cadium nuts (not specified)
Control arm shaft, upper: Natural 30 percent gloss black paint
Core support: Semi-gloss black 30 percent gloss black paint
Cowl plenum air cleaner assembly: (not specified) 60 percent gloss black paint
Cylinder heads: Chevrolet orange paint Chevrolet orange paint
Dashboard, top, 1967-68: (not specified) 30 percent gloss paint
Deck lid striker, 1967 all: (not specified) Silver cadium dichromate
Dip stick and tube: (not specified) Natural metal finish
Disc brake caliper mounting brackets (not specified) Gold cadium dichromate
Disc brake backing plates: (not specified) Silver cadium dichromate
Disc brake calipers: (not specified) Semi-gloss black paint or natural finish acceptable
Distributor: Natural Natural aluminum finish
Distributor hold-down bracket: Natural Chevrolet orange paint or natural metal finish
Door latch mechanism screws, (three in door) 1967: (not specified) Silver cadium dichromate
Door striker: (not specified) Silver cadium dichromate
Drive shaft: (not specified) Natural metal finish
Engine block: Chevrolet orange Chevrolet orange paint
Engine lift hooks: Natural Chevrolet orange paint
Engine vent tube: Semi-gloss black 60 percent gloss black paint
Exhaust manifolds: Natural Natural cast iron finish
Fan blade: gloss black Black paint, approximately 60 percent gloss
Fan clutch assembly: Natural Natural metal, silver or gold cadium dichromate
Fender bolts: Phosphate Black phosphate
Fender skirts, front: Semi-gloss black 30 percent semi-gloss black paint
Firewall: Semi-flat black 30 percent semi-gloss black paint
Firewall stamps "P", "T", "B": orange or green paint orange or green paint, Norwood cars only
Floor pans: (not specified) 30 percent gloss black paint, original cars usually have body color over spray on the floor boards
Flywheel shield: (not specified) Chevrolet orange paint
Front springs: (not specified) Natural finish
Front cowl area under cowl panel: (not specified) body color to edge of firewall, where firewall and body color meet is a feathered line, not a crisp taped line
Front cowl panel retaining screws: (not specified) Silver cadium dichromate
Front fender support bars: (not specified) 60 percent gloss black paint
Front spindles: (not specified) Natural metal finish
Front sway bar mounting kits: (not specified) Silver cadium dichromate
Gas lines: (not specified) Natural metal finish
Gas tank: (not specified) Natural finish, galvanized
Gas tank straps: (not specified) Natural or semi-gloss black paint
Grille, front 1967 RS and non-RS: (not specified) Black
Ground straps, engine bay: Natural copper Natural copper finish
Harmonic Balancer: Chevrolet orange Chevrolet orange paint
Heater box cover: gloss black 60-70 percent gloss black paint, (more gloss than firewall)
Heater hose nipple Intake: , Silver cadium Silver cadium dichromate
Heater hose nipples, water pump: Chevrolet orange (not specified)
Hood hinges: Phosphate gray or black phosphate
Hood latch assembly: Phosphate gray or black phosphate
Hood latch assembly spring: (not specified) gloss black paint
Horns: gloss black 30 percent gloss black paint
Horn relay: Silver cadium Silver cadium dichromate
Hose clamps: Silver cadium Silver cadium dichromate
Intake manifold: Natural aluminum Natural aluminum finish (clear coating intake manifolds not acceptable!)
Intake manifold bolts, 302 "TR", "M", "A", non-shouldered hex head style: Silver cadium Silver cadium dichromate
"L" bracket, (holds master cylinder manifold/switch to stud on brake booster): (not specified) 60 percent gloss black paint
Leaf spring shackles: (not specified) 30-60 percent gloss black
License plate mounting brackets: (not specified) 60 percent gloss black paint
Master cylinder: Semi-gloss black 60 percent gloss black paint or natural finish acceptable
Master cylinder cover: Gold cadium Gold cadium dichromate
Master cylinder cover retaining wires: Silver cadium Natural metal finish
Oil cap: Chrome Chrome
Oil fill tube: Chrome Chrome
Oil pan and bolts: Chevrolet orange Chevrolet orange paint
Parking brake cables: (not specified) Natural metal finish
Power brake booster: Gold iridite Gold cadium dichromate
Power steering brackets/braces: Semi-gloss black 60 percent gloss black paint
Power steering pump: gloss black (not specified)
Proportioning valve: Natural or semi-gloss black Semi-gloss black paint or natural finish acceptable
Proportioning valve bracket: Gold cadium Gold cadium dichromate
Pulley, crankshaft: Natural 60 percent gloss black paint or gray phosphate acceptable
Pulley, power steering: Semi-gloss black (not specified)
Pulley, power steering crankshaft (not specified) 60 percent gloss black paint
Pulley, power steering pump: (not specified) 60 percent gloss black paint
Pulley, water pump: Semi-gloss black gray phosphate or 60 percent gloss black paint
Radiator: gloss black paint full gloss black paint
Rally wheels: (not specified) Semi-gloss Argent Silver paint front side, semi-gloss black paint back side
Rear axle housing: (not specified) 30-60 percent gloss black paint, natural finish acceptable
Rear brake backing plates: (not specified) 30-60 percent gloss black paint
Rear springs: (not specified) Natural finish or gray paint
Rear wheel wells: (not specified) Black undercoating
Shift linkage: (not specified) gray/black phosphate finish
Shock absorbers: (not specified) Semi-gloss gray paint
Spark plug shields: (not specified) Silver cadium dichromate
Spark plug wire loom brackets: Chevrolet orange Chevrolet orange paint
Starter motor: Semi-gloss black 30-60 percent gloss black paint
Starter motor brace: Semi-gloss black 30-60 percent gloss black paint
Starter bolts: Silver cadium (not specified)
Steering box: (not specified) Natural metal finish
Steering knuckles: (not specified) Natural metal finish
Steering linkage: (not specified) Natural metal finish
Sub-frame: (not specified) 30 percent gloss black paint
Sway bar, front: (not specified) Semi-gloss black paint or natural finish acceptable
Sway bar brackets: (not specified) 60 percent gloss black paint
Thermostat housing: Natural aluminum Silver or Chevrolet orange paint
Throttle linkage: Phosphate (not specified)
Throttle rod: (not specified) Silver cadium dichromate or natural metal finish
Timing chain cover and bolts: Chevrolet orange Chevrolet orange paint
Traction bar, 1967 only: (not specified) 30-60 percent gloss black paint
Transmission: (not specified) Natural aluminum finish
Transmission crossmember: (not specified) 30-60 percent gloss black paint
U-bolts, driveshaft: (not specified) Natural metal finish
Underside of front hood: (not specified) 60 percent gloss black paint
Valance panel, front lower: (not specified) painted body color on inside of panel
Valve covers: Chrome Chrome
Voltage regulator: gloss black painted cover with silver cadium base gloss black painted cover with silver cadium base
Water pump: Chevrolet orange Chevrolet orange paint
Water pumps bolts: Chevrolet orange (not specified)
Windshield washer pump cover: Black plastic, natural finish Black plastic, natural finish
Wiper motor: gloss black paint gloss black paint
Back to top
Old 02-08-2009, 05:08 AM
beater68427 beater68427 is offline
Good quote on Jerry's book, I should buy it for a barometer, I'm curious on the rear my BE 12 bolt looks like the tubes are painted but the center natural and rear cover as well, who knows.....
Old 02-09-2009, 12:25 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Here is a pic of a supposedly real Tonawanda DZ engine and supposed POP for the car.
Old 02-09-2009, 01:07 AM
William William is offline
John Z, who was there, has stated that rear axles were painted black complete with drums. Lines and cables added later, yoke was masked. There are a number of axle photos in vintage car magazine tests and the axles look shiny black. One of the best is ZL-1 #3 in the Aug '69 HP Cars.
Remember this stuff was not cleaned, degreased or primed prior to paint. I doubt the paint adhered for long.
Old 02-09-2009, 02:09 AM
Unreal Unreal is offline
Not to switch from paint vs. bare hooks for sb. There was a thread on Camaros.net a few weeks ago with the shape of the driver side hook for bb. There was one with a gusset at the bend in the bracket and rounded corners at the upper edge, one had no gusset and sharp corners, and one like in the pics above with rounded corners and no gussets. No resolution as to what years might have gotten what, except that I'm fairly certain mine (which are like the above pics) are for 69.
Old 02-09-2009, 02:27 AM
I love pics! they speak a thousand words, memory can be short I do have a couple pics of a build sheet stuck to rear cover not painted??? adds question, I did note one on here as well, so what we would be saying is they painted the housings before assembly??? cover added after, that does not make sence to me either, I agree pics are the best source and the older or closer to build time is best, I looked at another 10 bolt car all original today it was black, you could still see most on diff, so
Old 02-09-2009, 07:54 PM
JohnZ JohnZ is offline
Back on topic...
In general,here's what I believe happened,that may help answer a few questions that have been brought up,but by no means should this be taken as Verbatim.
The beginning of the engine dress line was a sea of racks full of engines and transmissions:small-block V-8's from Flint V-8 Engine and Tonawanda,big-block V-8's from Tonawanda,and L-6 engines from Flint Motor,plus manual transmissions from Saginaw and Muncie and automatics from Toledo,Cleveland,Warren,and Willow Run.
In the engine schedule area,the operator grabbed the next broadcast copy from the printer,verified the sequence number,noted the engine code required for that car,and moved an air-powered overhead hoist on traveling bridge rails over the correct engine rack.The specified engine was hoisted * out of the rack and transferred to the next hook on the overhead engine dress line conveyor,where the throwout bearing (on manuals) was greased and installed,along with the clutch fork boot.Another operator on the other side of the line repeated the process with the specified transmission,
which was then installed and bolted to the engine.On automatics,an air tool was used to rotate the flexplate,and the converter bolts were driven,followed by the lower cover.
The VIN derivative numbers were stamped in the next operation on both the engine pad and the transmission,using a gang-stamp holder and a dead blow hammer.From here on,all the crucial detail dress ornaments were added like plug wires,coil,engine harness,battery cables,carburetor,pulleys,alternator,starter,fan and clutch,A/C compressor,power steering pump,transmission cooler lines and fill tube,A.I.R. pump,diverter valve and air manifolds,drive belts,dipstick and tube,oil filter,engine and transmission mounts,PCV plumbing,vacuum fittings,fuel pump and fuel line,radiator hoses,and (if applicable) the transmission-mounted 4-speed manual shifter and linkage was installed and adjusted (3-speed manual floor shifters were mounted on the cross-member and adjusted later on the Chassis line).
Engine oil and transmission lube were added,and the completed engine/transmission assembly was conveyed to the chassis line for installation in the subframe.The engine line inspector wrote the engine,transmission and carburetor codes on the broadcast copy and put the sheet in a box for pickup by the scheduling clerk,which was needed to create the Protecto-O-Plate at the end of the assembly line.
*The front & rear engine pull hooks were most likely installed before this moment,to allow many of the procedures that followed to take place.
That's exactly how it was done, lifted directly from my "First-Generation Camaro Assembly Process" paper at http://www.camaros.org/assemblyprocess.shtml ; however, the engine lift brackets were installed at the engine plants, and were part of the engine as-shipped to the car assembly plants.
My Group at the Chevrolet Pilot Line in Flint developed the engine lift brackets in 1967 for the 1968 model year, and the corresponding plant engine hooks used on the Engine Dress Lines. Photo below shows the typical assortment of engine hooks required in an assembly plant prior to 1968 for carrying various engines by the exhaust manifolds on the left, and the only two hooks required for 1968 engines on the right.
There were constant battles with the Finance people for the first couple of years over leaving the brackets on the engines vs. removing them at the assembly plants after engine installation and returning them to the engine plants for re-use; this direction changed several times, and eventually they were left on the engines.
'69 Z/28
Fathom Green
CRG
