Old 05-24-2021, 09:39 PM
scuncio's Avatar
scuncio scuncio is offline
Sure turned out nice. Is that a GM front bumper?
NorCam (05-25-2021)
  #782
Old 05-24-2021, 10:18 PM
NorCam's Avatar
NorCam NorCam is offline
Yes, Tony. An original that Ron spent some time on it to cure some warping that was present. Fits fairly well now for a 50-year-old bumper and has a little character to it.
scuncio (05-24-2021)
  #783
Old 05-25-2021, 12:05 AM
R68GTO R68GTO is offline
I really like the fitment of that rear tire/wheel combo. Can you tell me the wheel size & backspace along with tire size?
The Following User Says Thank You to R68GTO For This Useful Post:
NorCam (05-25-2021)
  #784
Old 05-25-2021, 12:57 AM
Z282NV's Avatar
Z282NV Z282NV is offline
Great work on this Camaro. I bet you can't wait to take the first rip down the road with it!
The Following User Says Thank You to Z282NV For This Useful Post:
NorCam (05-25-2021)
  #785
Old 05-25-2021, 04:16 AM
NorCam's Avatar
Jim, the rears are American VN30958561 Torq-Thrust Original Silver in 8.5" width and 3.75" backspace. Tires are Pro Trac #72146 in the old N50/15 size.
You know it. In just a few weeks, it will rumble!
The Following 2 Users Say Thank You to NorCam For This Useful Post:
R68GTO (05-25-2021), Z282NV (05-31-2021)
  #786
Old 05-30-2021, 07:36 PM
bbbenny bbbenny is offline
Default Day=2
Graeme, Your projects, are nothing but pure works of art! BBBenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
The Following User Says Thank You to bbbenny For This Useful Post:
NorCam (05-30-2021)
  #787
Old 05-30-2021, 10:35 PM
NorCam's Avatar
Thanks! I'm trying here Benny...I'm trying.
Old 05-30-2021, 10:46 PM
NorCam's Avatar
Spent some time swapping out the narrow traction bars for the correct era square bars from Lakewood. I have some 4* wedges coming and will hold off tightening things up until they get here. I haven't used the wedges before so I'm not totally sure where they go in relation to the lower insulators? I'm assuming they slide in from the rear (underside) and go between the lower traction bar mounting plate and the rubber insulator?
In any case, here's what the new square bars will end up looking like under the car. I'll finish up some pictures after I get the wedges installed and set the suspension with weight on the car. Inching closer here.
The Following 7 Users Say Thank You to NorCam For This Useful Post:
big gear head (05-31-2021), Dave Rifkin (05-31-2021), dykstra (05-31-2021), HawkX66 (06-03-2021), markinnaples (05-31-2021), PeteLeathersac (06-01-2021), x77-69z28 (05-31-2021)
  #789
Old 05-31-2021, 01:39 PM
rszmjt rszmjt is offline
Graeme, The wedges are actually designed & used to go on top of springs to maintain the correct pinion angle on cars that sit high or lifted 4x4 application. If your using them to change the traction bar angle I would get some deep/ long nuts, (I think they are 5/16 UNF ) to replace the lower Centre spring nut, so that the lower cushion can still be used. The thickness of the wedges will probably pull the stock short nut out of the lower spring insulator/cushion, causing the traction bar not to be located properly. If the Centre spring bolt has been trimmed off just below the thin stock nut, you will have to get new center spring bolts to maintain thread perch length with the deep nuts, , Standens in Calgary has them BTW.
The Following User Says Thank You to rszmjt For This Useful Post:
NorCam (05-31-2021)
  #790
Old 05-31-2021, 02:58 PM
rlw68's Avatar
rlw68 rlw68 is offline
Do you have the install instructions? On step 9, there is some info regarding the wedges.
LOL, I took the traction bars OFF mine
Rob
1969 Camaro Z/28. Norwood 02D. Lemans Blue
The Following User Says Thank You to rlw68 For This Useful Post:
NorCam (05-31-2021)
