Old 03-21-2003, 12:48 PM
Default Re: Correct me if I'm wrong ............
I found my Cam Card for the cam that I put in my Yenko. Where can I go to find the spec's for the stock LT1 cam from GM/Crane?
If I list the spec's for both cams, can you guys predict how my Comp Cam will perform compared to the stock Crane?
Old 03-21-2003, 01:02 PM
Chevy454 Chevy454 is offline
I believe THIS is your card.
Old 03-21-2003, 02:02 PM
Cool,
Thx,
[img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 03-25-2003, 07:34 PM
Original 2182 Cam;
Lift: In; 459 Ex; 485
Dur @ .05: In; 242 Ex; 254
Centerline: 116 (I think)
My Comp Cam;
Lift: In; 510 Ex; 530
Dur @ .05: In; 242 Ex; 250
Centerline: 106
Rob/Pete/Sam;
Is there a big difference in rear wheel hp/tq between these two cams since I'm using the stock manifolds, smog pump, and Gardner Exhaust with resonators?
Old 03-26-2003, 12:55 AM
Marlin, That seems to be a pretty high lift cam. Sometimes your rpm's and torque are hindered with a very restrictive exhaust.Your engine can not breathe properly, hence performance is hindered. Too much cam and no headwork can hurt also. Do you have enough vacuum to stop? Sam [img]/ubbthreads/images/graemlins/eek.gif[/img]
Old 03-26-2003, 12:59 AM
CHEATER [img]/ubbthreads/images/graemlins/[/img]
Peter
Pete Simpson 1962-2013 RIP
Owen Simpson
Eric Simpson
Old 03-26-2003, 11:41 AM
I have plenty of vacuum, 18 at idle. The only thing I wanted was a lower C/L, to keep some compression into the engine at lower rpm. I agree the extra lift is irrelevant due to the factory manifolds, smog (not cheating!) and factory exhaust with resonators (not cheating!!).
If I could do it over again, I would probably go with the Crane since I really don't drive it that much. And, so Pete wouldn't bust on me some day at the track [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 03-26-2003, 01:17 PM
Peter
If that isn't the Pot calling the kettle Black!
Just light hearted ribbing Pete. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 03-26-2003, 01:50 PM
Yea!! What he said!
Mr M20 trans and no smog [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 03-27-2003, 04:41 AM
Marlin:
Just curious...is this your current cam (from Comp)? Check the part number & specs and let me know...
