#61
Gas tank sending unit to under body ground bolt. This is a very unique bolt that is not being reproduced. It has oversize threads with a blunt tip and captured star washer and a recessed flanged head with E/o head marking. And an undersized head 1/4" across the flats. It has perfect original plating. Usually these are completely rusted. Looks like it was plated yesterday. $17.50 PPFF
************SOLD************ Last edited by Enoch; 08-04-2020 at 03:30 PM. |
#62
Very nice original set of 67 through 69 rally sport backup light lens mounting screws. What makes these different from the reproductions is the flat spot that is stamped in a circle around the cross hatch depression on the front. $10. PPFF
#63
Excellent original unrestored front end fender to cowl mounting bolts. These are correct for the upper cowl and for the lower cowl. These were used when more than 2 shims were in place. Very nice unrestored pieces.$17.50. PPFF ************SOLD************
#64
************SOLD************* Last edited by Enoch; 04-21-2020 at 12:39 AM. |
#65
My last pair of double and single Pole MB restored courtesy light door jamb switches. $40 for the pair. PPFF ************SOLD************
#66
2 replated, restored Original assembly line installed battery hold down clamps with original manufactures stampings on them. As nice as you'll find. Just need a coat of black paint. $25 each. PPFF
************SOLD************ Last edited by Enoch; 08-04-2020 at 03:31 PM. |
#67
Rich sent you an email on buying front and rear license plate sets and nos r/s bumper piece. Thanks Joe
| The Following User Says Thank You to bugsy For This Useful Post: | ||
Enoch (08-04-2020) | ||
#68
Original smog pump mounting hardware for small and big block. 69 on up Camaro Chevelle Nova Impala.
Set 1 [] headmarking long pivot bolt and [] short adjusting bolt. Set 2 RBW long and short bolts Set 3 EWF long and short bolts $25 per set shipped to the lower 48 ppff |
#69
Original 69 Hurst shifter reverse Rod part number 5771. Remove this from a 69 pace car 25 years ago and put an aftermarket shifter in. $30. Ppff very nice original piece
#70
Excellent original 3 wire plastic loom for small block motors. Excellent condition. $15 PPFF
