Old 01-30-2023, 09:30 PM
Hi Paul, I am following along. I know that you had been looking forever for a Camaro in this color. So glad you found one!
Old 01-30-2023, 11:38 PM
X66 714's Avatar
X66 714 X66 714 is offline
My Corvette bronze 68 Z/28 is the first Camaro I ever purchased. had it since March 1976...Love it. I'm following along also. Keep up the good work....Joe
The Following User Says Thank You to X66 714 For This Useful Post:
Xplantdad (01-30-2023)
Old 01-31-2023, 05:52 PM
Canuck's Avatar
Canuck Canuck is offline
Mondays work on the Camaro, found some prior damage on the left rear QP. Mark is an amazing fabricator and will make a replacement piece.
I am pretty pleased with the condition of what’s been found so far. A few spots on the rear wheel lips , minor dents in a few places, otherwise a solid car.
www.vancouverclassiccars.com
The Following 8 Users Say Thank You to Canuck For This Useful Post:
1967Z28 (02-01-2023), 69M22Z (01-31-2023), big gear head (01-31-2023), Dave Rifkin (02-04-2023), dykstra (01-31-2023), olredalert (01-31-2023), RPOLS3 (01-31-2023), X66 714 (01-31-2023)
Old 01-31-2023, 09:56 PM
Canuck's Avatar
Should have included this engine,sub frame earlier. Rebuilt correct date coded MO block, all components are date coded between Jan 9 (distributor and Alternator) Water pump, fuel pump and starting motor are Mar. Carb is April 2, Block is Mar 23 and Heads are late Feb casting, trans is Feb 1968. I have all the smog stuff but decided to stick with headers.
The Following 10 Users Say Thank You to Canuck For This Useful Post:
1967Z28 (02-01-2023), 69M22Z (01-31-2023), big gear head (01-31-2023), Dave Rifkin (02-04-2023), dykstra (01-31-2023), L78_Nova (02-01-2023), napa68 (02-01-2023), olredalert (02-01-2023), Pro Stock John (01-31-2023), RPOLS3 (02-08-2023)
Old 01-31-2023, 11:38 PM
black69 black69 is offline
thanks on the tire info, they do look good, just some white paint on the goodyear font and they look good to me!! way too nice to be rollers. Wish I had a set.
Again, looks like your car is coming along great. I got ziebart tar stuff all over my 68z, engine compartment, underbody. WD40 seems to take it off without damage, slow process.
Old 02-03-2023, 07:45 PM
Canuck's Avatar
Thursday Feb 2 shop update. All the paint is now off and prev minor damage has been corrected to todays restoration standards.
Rear valance had a crease and was fixed with filler. Mark has re worked the metal back to O filler needed.
Super clean quarter panel.
This may be all until next week, next steps will be hood and trunk panels, valances and header panel.
The Following 15 Users Say Thank You to Canuck For This Useful Post:
169indy (02-03-2023), 1967Z28 (02-04-2023), 69M22Z (02-03-2023), big gear head (02-03-2023), cruiserofland (02-04-2023), Dave Rifkin (02-04-2023), dykstra (02-03-2023), enio45 (02-04-2023), L72Chevelle (02-03-2023), markinnaples (02-04-2023), napa68 (02-03-2023), olredalert (02-03-2023), RPOLS3 (02-08-2023), sixt9rsx33 (02-04-2023), Xplantdad (02-06-2023)
Old 02-07-2023, 02:51 AM
Kurt S Kurt S is offline
Why did you remove the lead from the 1/4 seams?
Kurt S - CRG
Old 02-07-2023, 02:55 AM
Canuck's Avatar
Default Seams
Old lead,might react to modern fillers and or paints.
Old 02-08-2023, 10:36 PM
Never heard of this. The lead was not smooth on my 69, so I took it down to clean bare lead and re-leaded it. I used epoxy primer over it, and have had no issues. If figured the lead was less likely to shrink over time as opposed to any other filler. That's been 15 years ago, and all is still good.
I didn't look back to see; did Mark use a different filler in place of lead? Or did he just use new lead?
Would be interested to know.
Old 02-07-2023, 07:01 PM
Canuck's Avatar
This week, metal finishing wrapped up, mysterious dent in room massaged out.
Right quarter in DTM, very straight.
Roof was scrapped with a razor blade, anybody need a cup of dried Corvette Bronze
1967Z28 (02-07-2023), 69M22Z (02-07-2023), big gear head (02-07-2023), dykstra (02-08-2023), napa68 (02-07-2023), olredalert (02-07-2023), PeteLeathersac (02-08-2023), RPOLS3 (02-08-2023)
