Old 06-22-2023, 08:30 PM
A12pilot's Avatar
A12pilot A12pilot is offline
Yenko Advertising Member
Ha! That’s a good point, Joe, and funny you say that. I’m stamping the data plate and chassis plate on the cowl with the chassis number one after Walter’s just for fun.
Things finally getting back to normal around here, so updates next week!
Cheers
Dave
The Following 9 Users Say Thank You to A12pilot For This Useful Post:
69M22Z (06-23-2023), Billohio (06-23-2023), Charley Lillard (06-23-2023), dykstra (06-22-2023), markinnaples (06-24-2023), PeteLeathersac (06-23-2023), Woj (06-24-2023), Xplantdad (06-22-2023), Z282NV (06-23-2023)
Old 06-25-2023, 02:50 AM
A12pilot's Avatar
It's in! No collateral damage! Before I installed it I fabbed up the center mounted generator/alternator brakets, but left that off during the install. You'll also see the clutch and brake master cylinders along with the remote power brake booster tucked up in the driver's side inner fender. Brake lines, fuel lines, radiator, exhaust all this week.
Getting closer!
Cheers
Dave
The Following 17 Users Say Thank You to A12pilot For This Useful Post:
67 Nova Boy (11-16-2023), 67since67 (06-25-2023), 69M22Z (06-25-2023), Arrowsmith (06-25-2023), big gear head (06-25-2023), carnut4life (06-25-2023), Dave Rifkin (06-25-2023), dykstra (06-25-2023), Jonesy (06-25-2023), L78_Nova (06-30-2023), L_e_e (06-25-2023), olredalert (06-25-2023), scuncio (06-28-2023), Tenney (06-25-2023), Too Many Projects (06-25-2023), Woj (06-26-2023), Z282NV (06-25-2023)
Old 06-25-2023, 12:48 PM
Gerhard Gerhard is offline
Congratulations - an impressive achievement - to build a car from scratch. I wish I had your talent.
A BMW 507 maniac from Austria.
Old 06-25-2023, 04:10 PM
----Really good to see the engine and trans in place. What a car this is becoming!!!.....Bill S
Old 06-25-2023, 05:47 PM
A12pilot's Avatar
Thank you, Gerhard. It's been quite a fun endeavor! I got the car on all four wheels under its own weight, added weight to compensate for fuel, seats, etc. I measured for the driveshaft and will get that made this week.
Very happy with the ride height but it should settle some after I get it on the road. It's adjustable at all four corners.
OK, back up in the air it goes for exhaust, brake and fuel lines, emergency brake cables, and some other minor things.
Cheers
Dave
The Following 11 Users Say Thank You to A12pilot For This Useful Post:
67 Nova Boy (11-16-2023), Big Block Bill (06-28-2023), big gear head (06-25-2023), Dave Rifkin (06-26-2023), dykstra (06-26-2023), Jonesy (06-25-2023), L78_Nova (06-30-2023), markinnaples (06-26-2023), olredalert (06-25-2023), Tenney (06-26-2023), Z282NV (06-29-2023)
Old 06-25-2023, 05:54 PM
67since67's Avatar
Dave...have you informed us of that beautiful '63 Vette??
Old 06-25-2023, 07:41 PM
A12pilot's Avatar
Hmmmm....I have not. Another thread with a description comin' in HOT!
Cheers
Dave
Old 06-26-2023, 12:00 PM
dykstra's Avatar
dykstra dykstra is offline
Simply Amazing!!!
Dave Dykstra
NCRS#66003
Dykstra Motorsports
Old 06-26-2023, 12:47 PM
A12pilot's Avatar
Thanks Dave! I appreciate the comment! More progress and updates this week.
Cheers
Dave
Old 06-28-2023, 12:58 AM
A12pilot's Avatar
Radiator is in along with upper and lower hoses, front brake lines run, and I'm working on the mounting bracket for the dual electric fans. The 507 had an option of a "Tropical Cooling Kit" which used dual Jaguar electric fans to supplement the engine fan. I upgraded those to bigger CFM yet they retain the stock look. More on that later.
In fun news, Here's the knock-off knock-offs! Very happy with it. There's a ring that the lugs pass through which has the center post welded to it. The cap goes over that post and is sandwiched to the wheel byb the spinner. The tire shop will put these center adapters on the balancer for me so there's no weird wobble or out of balance issues at speed.
Tomorrow I'll finish the fans and start on the exhaust.
Cheers
Dave
The Following 15 Users Say Thank You to A12pilot For This Useful Post:
67 Nova Boy (11-16-2023), 69M22Z (07-02-2023), Big Block Bill (06-28-2023), carnut4life (06-28-2023), Dave Rifkin (06-30-2023), dykstra (06-28-2023), Hawkeye (06-28-2023), L78_Nova (06-30-2023), markinnaples (06-28-2023), olredalert (06-28-2023), PeteLeathersac (06-29-2023), RPOLS3 (06-28-2023), Tenney (06-28-2023), Xplantdad (06-28-2023), Z282NV (06-29-2023)
