Old 04-21-2019, 06:50 PM
Lee Stewart's Avatar
Old 04-21-2019, 06:51 PM
Old 04-21-2019, 06:52 PM
Old 04-21-2019, 06:53 PM
Old 04-21-2019, 06:54 PM
Old 04-21-2019, 07:01 PM
Japan's Coolest Café (Hipopo Papa Cafe on Japan’s Hayashizaki Matsue Coast) Bathroom Is Surrounded by a Massive Aquarium
Old 04-21-2019, 07:04 PM
Have you checked the expiration dates on your spices recently? You should.
Old 04-21-2019, 07:09 PM
The last thing you want to see when you turn on the light in the bathroom late at night is a spider in the middle of the floor. Also, it can make your skin crawl to watch one scurry across the bedroom floor and hide under a dresser before you can get to it.
If there’s one spider, that means there are plenty more. That’s not such a bad thing as spiders kill other pests in your home, but that doesn’t necessarily mean you want them anywhere near you.
There is an easy solution to repel spiders in areas of the home where you don’t want them, and that solution is: moth balls! Moth balls not only kill moths, but they can ward off other pests, such as spiders.
  1. Grab a Mason jar and use a drill to put three or four holes into the jar’s lid.
  2. Take three moth balls and place them in the jar and close the lid tightly. Make sure to avoid contact with skin and eyes when handling moth balls. It’s best to wear gloves and don’t inhale the fumes.
  3. Make one jar for each area where spiders are a problem.
  4. Be sure all of the jars are tightly sealed and out of reach from children and pets.
  5. The effect of the moth balls should last up to six months.
Old 04-21-2019, 07:17 PM
Canuck's Avatar
Canuck Canuck is online now
Default Chrysler
In a 69 Dodge Charger with power windows, if you don’t have the keys on you and you need to close the windows, turn on the emergency flashers, step on the brake, set the turn signal lever in the left or right signal position, and the power windows will operate.
Used to do this in my Dads 68 Chrysler. Flashers,brake Pedal and turn on Radio while waiting.
www.vancouverclassiccars.com
