Old 03-08-2023, 04:24 AM
Yeah, I have had no luck getting the oil stains out of my concrete. Even using acetone leaves a dark spot. I have some HC microbial stuff on the way.
https://www.covertecproducts.com/pro...r-oils-diesel/
Old 03-08-2023, 12:57 PM
That would need to be a very long and sturdy ramp. Those stand offs are used for vertical stop plates, to prevent a vehicle from rolling off too and are just bolted. Not sure I would trust that arrangement to hold the weight of a car ??
Most 4 post lifts these days have wheels so you can roll them around. You could roll one up to one of those, lift the car up right in front of it and roll it on.
Old 03-08-2023, 03:04 PM
Too Many Projects's Avatar
That's true and would work. I had my 2 lifts inline in my old shop and have transferred cars from the back lift to the front one, and vice versa. Rather intimidating doing that 6ft off the floor..
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 03-28-2023, 09:08 PM
scuncio's Avatar
scuncio scuncio is offline
Lynn- spent four hours on a small area of my floor, with the Zep citrus cleaner and then the Zep purple degreaser, and still I’m not having much success getting these oil stains out. Did you have any luck with the microbial cleaner?
Old 03-28-2023, 11:28 PM
It did not do as well as I had hoped.
Old 03-29-2023, 02:13 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Tony - you might consider renting a ride on floor scrubber. All of the commercial cleaning companies that I've seen use this product with good results use the ride on scrubber. Probably have to make several/multiple passes with it too. This is not a miracle solution if the machine oil has been there for decades though, once it gets into the concrete unless you shot blast the surface (which creates other issues and even then it's likely the stain is permanent) it's not coming out.
Jake Dykstra
Dykstra Motorsports
Old 03-29-2023, 04:53 PM
dustinm dustinm is offline
Sorry to hear that Tony. Part of the problem is that the oil wicks into the grain structure of the cement so therefore you need a something to get in and remove the oil and then the left over carbon deposits. If you cant live with that then you are looking at light surface grinding, acid etch, and finally an epoxy coating.
Old 04-05-2023, 04:14 PM
CDNL-78 CDNL-78 is offline
Tony, rent a bush hammer and try a sample area where the staining is at it worse. You can go to any depth to see where the staining/saturation ends. As mentioned before, the concrete is porous and most likely soaked in pretty good. If this bush hammering becomes an option, you can rent a scabbler (does a larger area at a time) and do the entire floor and then skim coat it with an epoxy. Good luck.
Darcy
2019 ZL1 A10 Camaro Convertible
Davenport Stage 2 tuned.
Old 10-14-2023, 09:19 PM
OK, Tony, time for an update. Been wondering where you are at with this a for a while now. Hopefully, you have done something with the floor and are now building either of your Camaros...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
The Following 4 Users Say Thank You to Too Many Projects For This Useful Post:
COPO (10-15-2023), dykstra (10-16-2023), L_e_e (10-15-2023), napa68 (12-10-2023)
  #60
Old 12-10-2023, 04:59 PM
I’m curious about this shop progress also.
