Old 01-28-2022, 10:27 PM
L78_Nova's Avatar
L78_Nova L78_Nova is online now
Default 1970 L-78 Nova Restoration; Saga of The Green Bastard
Tub time. The flange of the tub is sandwiched between two layers at the top. Getting the old metal out from in between was a challenge. The huge holes on the outermost flange were two-fold. 1) because it was so hard to separate, it required a larger drill size. 2) My game plan was to plug weld to the inside flange first (through the larger hole). Then finish welding the outer flange.
Name:  wheel Tub 00.jpg
Mock up with tub
Name:  wheel Tub 01.jpg
Drill, drill drill, drill
Name:  wheel Tub 03.JPG
And getting welded... You can see I took the opportunity of no quarter to work on the trunk floor.. lots of old drilled holes (battery in trunk ?) and lots of hammer and dolly work. While things were opened up I was stripping the "to be painted" surfaces to bare metal and the "no show" surfaces were getting wire wheeled sanded and either Por-15 if surface rusted or DP90 if bare and clean.
Name:  wheel Tub 04.jpg
70 Chevelle SS-454 LS-5 M-22
The Following 3 Users Say Thank You to L78_Nova For This Useful Post:
big gear head (01-29-2022), NorCam (01-29-2022), olredalert (01-29-2022)
  #52
Old 01-28-2022, 11:19 PM
L78_Nova's Avatar
Continued welding
Name:  Wheel tub 01.jpg
Front lower inside, with faux spot dimples... plug welded in between.
Name:  Wheel tub 02.jpg
Rear Lower inside
Name:  Wheel tub 03.JPG
Bottom rear edge
Name:  Wheel tub 04.jpg
Top flange
Name:  Wheel tub 05.jpg
The Following 2 Users Say Thank You to L78_Nova For This Useful Post:
  #53
Old 01-28-2022, 11:24 PM
L78_Nova's Avatar
Name:  Wheel tub 06.JPG
Name:  Wheel tub 07.jpg
The Following 4 Users Say Thank You to L78_Nova For This Useful Post:
big gear head (01-29-2022), Dave Rifkin (01-29-2022), markinnaples (03-08-2022), NorCam (01-29-2022)
  #54
Old 01-29-2022, 02:17 AM
Woodrock Woodrock is offline
Nice work! I don’t have the skills for this, but I love to watch this part of a build more than anything for some reason…
Tony
The Following User Says Thank You to Woodrock For This Useful Post:
L78_Nova (01-29-2022)
  #55
Old 02-01-2022, 07:36 PM
Too Many Projects's Avatar
It all looks great.
I hope you fit the quarter panel along with the wheel house before welding.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
L78_Nova (02-01-2022)
  #56
Old 02-01-2022, 10:03 PM
L78_Nova's Avatar
Stripped out the old sandwiched quarter at base of rear window/trunk
A little repair in the corner (sorry poor picture)
Old 02-01-2022, 10:14 PM
L78_Nova's Avatar
Tail panel had been cut out as it had to be replaced due to some old repaired damage. Earlier in the sequence but had not yet included photos.
Name:  Tail Panel 01.jpg
Name:  Tail Panel 02.jpg
The Following User Says Thank You to L78_Nova For This Useful Post:
  #58
Old 02-01-2022, 10:35 PM
L78_Nova's Avatar
One advantage to having scavenged the replacement used inner door panel from the wrecker... I now had an original jamb to harvest the "telephone receiver". Recall the quarter which was cut off was a replacement GM panel with only half a receiver as with the replacement NOS GM panel I was now putting on. Well, we can fix that detail.
I tig welded the receiver in only because I wanted to practice with the tig.
Because of the previous jamb and inner door panel damage, It was best to also attach the jamb/striker reinforcement to the panel first. That way the quarter can be perfectly aligned and welded to the inner panel afterwards.
Old 02-01-2022, 10:57 PM
L78_Nova's Avatar
Door side of jamb
There is a small reinforcement piece that goes in the corner of the quarter window. This piece was completely missing from the previous repair. Unfortunately I was not aware of it when I scavenged the repair piece from the wrecker. I did my best to get some phone pics of the LH side taping my phone to a stick and sliding it in there. Then fabbed a piece as close as I could from the pics
Old 02-01-2022, 11:32 PM
L78_Nova's Avatar
It all looks great.
Yes... many,many trial fits
