Old 09-02-2020, 01:24 PM
Enoch Enoch is offline
Banned
65 through 72 Corvette and 69 JL8 + J56 Camaro front caliper half mounting bolts. These four S bolts attach the two halves of the caliper together. Complete set for one car. Excellent head markings. Usually rusted. $40. PP FF ************SOLD************
Old 09-04-2020, 11:03 PM
Banned
Complete set of four original wagon wheel WB head marking front lower cross bar bolts. They don't reproduce these correctly. Very hard to find good originals. Lock washers and nuts included. $40 PPFF
Old 09-04-2020, 11:06 PM
Banned
Excellent original restored set of Rochester carburetor mounting bolts with A head marking and long studs with dimple on end. You won't find a nicer set. $45. Ppff
Old 09-04-2020, 11:10 PM
Banned
Original mid 69 and up large size 3/8 16 9/16 hex head sway bar bushing retainer mounting bolts. P head marking. Excellent survivor unrestored condition.$30. PPFF
Old 09-05-2020, 01:51 AM
Banned
Original evaporator housing clips. These clips retain the capillary tube and mounted to the evaporator box. The 2 metal ones are NOS and have the manufacturer stampings on them and are $20 each. The plastic one is an original piece it has its number 7 embossed on it.$20. PPFF
Old 09-05-2020, 01:55 AM
Banned
Original translucent white stop light switch original pal nuts. Excellent working condition.$20. PPFF
Old 09-05-2020, 01:59 AM
Banned
Original survivor condition 68 and 69 tripower coil mounting bracket with notch on the right hand side and original anchor head marking mounting bolts. Also included is the correct screw. All in unrestored survivor condition. $45 PPFF
Old 09-05-2020, 02:06 AM
Banned
Original survivor condition 67 tripower coil mounting bracket with notch on the right hand side and original RBW head marking mounting bolts. Also included is the correct screw. All in unrestored survivor condition. $45 PPFF ************SOLD************
Old 09-05-2020, 02:12 AM
Banned
Original set of unrestored survivor condition upper a arm alignment shims. included are 12 1/8 inch shims, 2 3/32 inch shims and 2 1/16 inch shims. Perfect for survivor.$50. PPFF
Old 09-05-2020, 02:16 AM
Banned
Original set of 4 big block windage tray studs. Excellent unrestored condition.$50. PPFF
