Old 04-16-2019, 11:25 PM
NorCam's Avatar
NorCam NorCam is offline
I use a Macs engine pivot (tilter) that bolts to the carb studs to lift engines. The thing really is slicker than snot for dropping engines down and positioning the mounts to drop right on. Adding the trans increases the load on those 4 studs and although this rig works awesome, I'm still a bit concerned about having it pull the carb studs and dropping an engine.
With the car being assembled and painted, the risk of it dropping it while going in over the front of the car has the potential to be catastrophic. Hence the reason I added the chain yesterday (as a safety). Adding the transmission weight onto those studs increases the chances of something failing so I have been putting the transmission in separately on the last 3 motors just to be safe. It's not hard to lift the transmission in and then add the rear mount after the fact.
The Following 4 Users Say Thank You to NorCam For This Useful Post:
HawkX66 (04-17-2019), KLars1 (04-17-2019), L_e_e (04-16-2019), SS427 (04-21-2019)
  #52
Old 04-19-2019, 03:44 AM
NorCam's Avatar
So with the engine now resting in place, we have since connected the clutch, installed the transmission and aligned the 3138 shifter with linkages. Today we cleaned up the original console, made the required carpet cuts and got the lower base installed with the wiring and oil pressure line in place. The console top was set in place near the end of the day and further cuts were made for the seat belts and seat tracks. I'll be finishing up the console, carpet and seat belts over the weekend with the rest of the interior to follow early next week. A mere 21 days left before the cars birthday and original shipping date of May 9th. Crack goes the whip.
Rebuilt Muncie M21 Trans with 3138 Shifter and Linkages
Mounted up but can't find the right bolts for the linkages. They're around here somewhere...gotta find them! (temporary bolts are in place for now)
Buttoning up the rear cross member and the transmission mount. Linkages are working great!
Using many restored original fasteners for this drive line, courtesy of Rich (Enoch)
One of my employees (Keith) helping me out as he cuts the carpet holes.
Original console and gauges cleaned up and installed.
Looking good for a 50 year old piece, and so is that un-restored shift handle.
The Z/28 is starting to look like a car again. Won't be long now. Tic Toc
The Following 8 Users Say Thank You to NorCam For This Useful Post:
big gear head (04-19-2019), Damien (04-23-2019), HawkX66 (04-19-2019), m22mike (04-19-2019), PeteLeathersac (04-22-2019), ScottG (05-07-2019), X66 714 (04-21-2019), x77-69z28 (04-22-2019)
  #53
Old 04-21-2019, 01:27 PM
napa68's Avatar
napa68 napa68 is offline
Looking good Graeme!
NorCam (04-21-2019)
  #54
Old 04-21-2019, 02:30 PM
outlawperformance outlawperformance is offline
That's going to be a sweet car!
The Following User Says Thank You to outlawperformance For This Useful Post:
NorCam (04-21-2019)
  #55
Old 04-21-2019, 02:48 PM
69z28302 69z28302 is offline
Love the Rally Green. I'm a fan of the less common colors
The Following User Says Thank You to 69z28302 For This Useful Post:
NorCam (04-21-2019)
  #56
Old 04-21-2019, 03:02 PM
mockingbird812's Avatar
Dang Graeme - she is looking FINE!!!!
Sam...
NorCam (04-21-2019)
  #57
Old 04-21-2019, 03:39 PM
Car looks fantastic! Great job by all!
The Following 2 Users Say Thank You to SS427 For This Useful Post:
NorCam (04-21-2019), purple panther (04-22-2019)
  #58
Old 04-22-2019, 05:25 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
Looks great!
Jake Dykstra
Dykstra Motorsports
The Following User Says Thank You to RPOLS3 For This Useful Post:
NorCam (04-23-2019)
  #59
Old 04-23-2019, 09:36 AM
Damien Damien is offline
As expected, very nice Graeme!
1969 SS 396/350 Chevelle
The Following User Says Thank You to Damien For This Useful Post:
NorCam (04-23-2019)
  #60
Old 04-23-2019, 03:16 PM
NorCam's Avatar
Been working hard with the interior the past few days while sorting out what seats to use in the car. I have a restored set of seats with new covers and an original survivor set but I'm really struggling between them as both have their +/- issues. A little more adjusting of the door panels is required but these originals are definitely going in. While back and forth with seats, we're also prepping bolts and hardware for the engine peripherals. Today we'll install the smog system, alternator, power steering, clutch fan and fuel lines.
The Following 2 Users Say Thank You to NorCam For This Useful Post:
HawkX66 (04-24-2019), ScottG (04-25-2019)
