Old 11-04-2015, 02:53 AM
Default Re: Horsepower for 69Z 302 w/#140 cam
Those 302's can have all the cam they want but ya gotta give it some gearing or you will not even be able to pull away from a stop sign.
Most important part in making a a SBC run is found under the trunk floor.
Old 11-08-2015, 01:11 PM
miket1 miket1 is offline
Thanks for all the info. and comments, the 140 is dialing in nicely since making several small adjustments, since I recently retired I have time to do what I like, such as detail my Camaro a bit, build & tune engines ,rebuild 12 Bolt rear ends, buy & sell early Camaro parts, rebuild Bravo outdrives on powerboats, and lots of other stuff that keeps me busy.
Thanks for the info. on Camaros.net forums, I will check it out.
69 Z28 Burgandy
Old 11-08-2015, 02:00 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">Those 302's can have all the cam they want but ya gotta give it some gearing or you will not even be able to pull away from a stop sign.
Most important part in making a a SBC run is found under the trunk floor.</div></div>
yep -- 4:88 or 5:38 depending on how tall the slicks are ... let her wind!
Old 11-08-2015, 02:43 PM
Most important part in making a a SBC run is found under the trunk floor. </div></div>
The broadcast sheet? [img]<<GRAEMLIN_URL>>/hmmm.gif[/img]
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 11-08-2015, 03:36 PM
Nope, the ring and pinion. Point is, gearing is what really helps a SBC perform.
Many want big cams, big carbs etc. and often overlook the gearing for the little motors.
Old 11-08-2015, 03:59 PM
I have a set of 4;10 &amp; 4;56 gears on the shelf I may try a 4;10 first
69 Z28 Burgandy
Old 11-08-2015, 04:59 PM
go to the .56's. I have no issues and I drive mine.
Old 11-08-2015, 06:28 PM
Plowman's Avatar
Plowman Plowman is offline
Try the gears you have on the shelf but Richmond make's New 4.33 gears also.
Old 11-08-2015, 07:04 PM
67 Nova Boy's Avatar
4:56...the 4:10 are not enough!
Dave
67 Nova Boy
Old 11-08-2015, 07:32 PM
John Brown's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 67 Nova Boy</div><div class="ubbcode-body">4:56...the 4:10 are not enough!</div></div>
The 68 Z I used to drive had 5.38's. Running kick down on the street at any speed up to 100 was just plain easy.
John Brown
