Old 10-01-2020, 06:07 PM
Grumpy's Toy VIII Grumpy's Toy VIII is offline
Carleen, agreed Reynolds prototype for GM. I have worked with and documented 21 variations of the GM aluminum blocks.
The 0-326711 you mentioned is definitely Can Am only. I have seen none with provisions for a mechanical fuel pump and agreed that mold was 68 only. It is also 4.440 bore and does have sleeves.
Who did you hear the production run number from ? That is interesting, I have never heard a definitive count other than from Bill Jenkins and Smokey Yunick who both state 70 short blocks cast between 67-69. This is Reynolds casting, not Winters. Different block, yes, even those that share the identical mold numbers:
3946052 and 3946053.
The Reynolds and Winters were cast from different alloys.
However, GM did turnover casting 052, 053 and 040 to Winters for '70 and '71 with big bore molds for Can Am teams.
If your into the Can Am stuff we should compare notes. A small group of us here in the USA that work on these are comparing notes to combine all this data and get it to those who restore these engines.
Old 10-01-2020, 06:45 PM
Carleen's Avatar
Carleen Carleen is offline
I have one of the 0-326711 Blocks.
I heard that Chevrolet ordered 20 Blocks (minimum order) of all 0-blocks.
Its the third Prototype / Eperimental casting of CanAm Big Block
They were supposed to be scrapped after trying them out but came out the back door to Racers. WDC Casting.
BTW Mine have provision for fuelpump.
The Following 2 Users Say Thank You to Carleen For This Useful Post:
olredalert (09-23-2024), PeteLeathersac (09-19-2023)
  #53
Old 10-01-2020, 07:00 PM
Carleen's Avatar
I have seen some 3946052 Can Am Block on ebay with Casting date early 69. Also bought one of these but got into trouble with the seller
Old 10-01-2020, 07:51 PM
Carleen's Avatar
Heres what I have found out.
And I thought WDC means Winter die casting
Can-Am blocks 68/69 - Winters
# 0-294550 = 4.250" bore with steel liners Experimental Prototype 67-68 Dry sump (427 ci)
# 0-321270 = 4.440" bore with steel liners Experimental Prototype 68 no boss for mechanical fuel pump(430, 465 ci)
# 0-326711 = 4.440" bore with steel liners Experimental Prototype 68 (430, 465 ci)
# 3946052 = 4.440" bore with steel liners (430, 465 ci)
# 3946053 = 4.440" bore with steel liners (430, 465 ci)
Can-Am Block 70 Winters
# 3946052 = 4.440" bore with steel liners (494 ci)
# 3946053 = 4.440" bore with steel liners (494 ci)
Can-Am blocks 71-72 - Reynolds
# O-399204 = 4.5" bore and steel liners (509 ci)
# O-495102 = 4.5" bore and no liners
ZL-1 Factory blocks - 1969 - Winters
# 3946052 427 ci.
# 3946053 427 ci
ZL-1 Factory blocks - 1997 & up
# 3946053 427 ci.
# 3992038 may be 4.44" bore w/ Liners - era?.
# 3946052 Yenko Casting LC 427
# 3946053 Yenko - Casting has YENKO
# 3946053 Yenko - Casting has Y E N K O
# 394605Y Yenko - Casting has Yenko Crest Logo
The Following User Says Thank You to Carleen For This Useful Post:
  #55
Old 10-03-2020, 01:11 PM
STEFS STEFS is offline
Yenko Premier Member
I still have some parts from the Can Am engine from Jenkins. If you need something give me a call. Thanks Joe 908-216-5614
Old 10-03-2020, 05:06 PM
RALLY RALLY is offline
Originally Posted by JoeC View Post
Only one 70 Camaro race car as far as I know
There was a 70 Camaro Grumpy's Toy VII that was more like a street/show car not a race car.
It had a ZL1 engine and 4 speed , straight bumper car. It had a prototype steel L88 hood that Chevy gave to Bill Jenkins for the car.
The 1970 COPO ZL1 Camaro that never made production
I have the hood to it so I am always looking for pictures of Grumpy's Toy VII
Beautiful looking drag car.
The Following User Says Thank You to RALLY For This Useful Post:
  #57
Old 09-23-2024, 06:41 PM
Kered-TCracingCA Kered-TCracingCA is offline
# 3946052 427 ci.
# 3946053 427 ci
# 3946053 427 ci.
I know this is a slightly aged thread, but for my first post here in this forum, I can help this history. Covering the Yenko blocks, the first batch commissioned by Yenko was thru the Winters people, so they had the snowflake. Then Yenko bought the molds and Winters asked him to knock off the snowflake for his personal production.
For the 1967 year, Chevrolet was building limitedly 427 Aluminum engines, going out to Chaparral/Hall. So 0-294550 were this batch. They lost about 11 of them in race testing! First ran at the 1967 Daytona 24 where one 2F was fitted, and one 2D modified was fitted, due to the other Team 2F, not being ready. They won Brands Hatch with this engine in 1967. Also these could be configured either internal dry sump or wet sump. I have put up some pictures up of this in the last thread on Corvette Forum (TCracingCA) showing this, in the recent thread talking of a White ZL-1 clone selling on Ebay.
For 1968 to the dissatisfaction of Jim Hall, Chevrolet opened it up to offering supply to all Teams with the next version 0-321270 (I believe 20 produced). They were working on revisions, and due to supply demand, they released 0-326711 upping production and supplied to more outfits, 60 units out to Can Am and like Drag Racer Grumpy Jenkins got 3 initially, might have acquired 2 more, along with other outfits like Motion. As these could be built with the famed short stroke and big bore, in 430 or 465. These were the first of the Chevrolet units, that get confused as being Reynolds 390 units.
For 1969-onward, these Chevrolet units made using 356 aluminum (preceeding the Reynolds 390 Alloy program), Chevrolet finally gave them a Part # and made some available to select Dealerships over the counter. As these were designed to go 430, 465, they are as said with the proceeding 0-dash units, confused often with the Reynolds 390 units that would come later. And this engine was thought to be the 454 version of the ZL-1 mistakenly. I have to study the 0-326711, the ZL-1, and this #3992038 block side by side, but I think this latest has some of the characterics of both the Chevrolet 356 Alloy series and the ZL-1. The ZL-1 needed some clearancing for 4.0 stroke and this latest engine had that done.
Part #3992038.
They had problems with the larger displacement sizes 441 (.060 overbore) & 509/510 (.060 overbore) especially, due to the cylinder bores being so close to the head bolts, so they would get fracturing. I can elaborate more on this later, like core shifting. Therefore to solve a number of issues, they went with Reynolds and their improved Alloy and better production casting techniques.
Reynolds 390 only offered a Block which became Chevrolet Part #3965755 for 430, 465, 495
Next Chevrolet was working with Reynolds for bigger bores and plating techniques, different piston plating, etc. they had larger bore development happening under
0-399204 & later 0-495102, but the Can Am series died.
A few ZL-1 units were found to be able to be built in large displacement, in an attempt to keep competitive to the Porsche 917/30 & 917-10, until the last year of the old Can Am in 1974, when a gas consumption formula negated the sheer horsepower advantage of the Porsche Turbos in 1972 & 1973, and thus Shadow won that final year.
The Following 13 Users Say Thank You to Kered-TCracingCA For This Useful Post:
169indy (09-24-2024), 1967Z28 (09-24-2024), big gear head (09-23-2024), dykstra (09-23-2024), John Brown (09-23-2024), Keith Seymore (09-24-2024), L78_Nova (09-23-2024), olredalert (09-23-2024), PeteLeathersac (09-23-2024), ragtop (09-23-2024), Rex (09-24-2024), rpoz11 (12-19-2024), Tenney (09-24-2024)
  #58
Old 09-24-2024, 01:01 AM
Rex Rex is offline
I have two of the 0-321270 blocks. One has sleeves and the other does not and doesn't appear to have ever had sleeves. The one without sleves has these characters hand stamped on the left rear corner of the block: RMC MOL and under that the number 10.
I was told on another forum the RMC stood for "Reynolds Massena Casting" (Massena, New York).
I also have an NOS 430 crank and pistons. Crank came from Grumpy Jenkins’ shop.
I’m trying to post pics but I’m having problems. ��
The Following User Says Thank You to Rex For This Useful Post:
Kered-TCracingCA (09-24-2024)
  #59
Old 09-24-2024, 02:26 AM
Hi Rex, glad to see you over here. On the project that we talked about an 0-dash history mostly, that I started sharing over on CF, this throws a curve ball, but a helpful curve ball. On the Chevrolet 1967-1970 Chevrolet 356 blocks, I have assumed one or more of those 0-Dash units might be the prototype for the Reynolds 390, so no panic. I have seen and read RMC (but even though I try to be on top of it all, sometimes my brain misses occasionally), I think even in this thread I read quickly to see if that was discussed. Those are still done up separate from the Reynolds 390 series, but the 0-321270 might just be that development/prototype run that led to the tooling up for Reynolds 390. Interesting. Thus let me dig some more on that history. I wanted to throw in to help, where I know smart guys on here, all of this hang out. As my personal email indicate, I know you know some stuff.
Therefore this line from my post is inaccurate, so removed this--->>>> Reynolds had nothing to do with these 1967-essentially thru 1970 offered engines or blocks using 356 alloy! Thus interest is to improve the History. I added 390 to two of the other mentions of Reynolds too. With your valued knowledge, I just gladly improved the accuracy overall of my post above. I still want to check into the RMC, go back and look at the castings for such, just to double check. Chevrolet was known to farm out Casting, so we had Winters, Alcoa, Reynolds, Tonawanda, and a few others. I wasn't pursuing who did what for Chevy, but that would be good to know information.
The Following 2 Users Say Thank You to Kered-TCracingCA For This Useful Post:
L78_Nova (09-24-2024), Rex (09-24-2024)
  #60
Old 09-24-2024, 03:01 AM
Crankshafts for 430 were:
P#3993803 Machined 3.47 stroke
P#3965746 Semi-Finished 3.4 to 3.8.
Another Semi-Finished one was available, but will have to search down that unit part number meant for 3.9 to 4.25 stroke.
Then we had:
P#3967811 3.76 (L88 unit) for 465 cubes
P#3963524 4.00 (LS7 unit-454) for 495 cubes
The Following 3 Users Say Thank You to Kered-TCracingCA For This Useful Post:
big gear head (09-24-2024), L78_Nova (09-24-2024), Rex (09-24-2024)
