Old 11-17-2005, 03:45 PM
Default Re: Driveability of high compression cars
Hope there is no quiz. LOL.
Old 11-17-2005, 06:12 PM
Baldy Baldy is offline
I buy the highest octain pump gas and mix it with Av. gas 50/50 mix. This works well on my 427 C.I.
Baldy Shockley
Old 11-17-2005, 08:26 PM
68l30's Avatar
68l30 68l30 is offline
I run my 327 on 94 Sunoco....It has a .003 deck (cut pistons & squared the deck front to rear and side to side ) with a true 10.5 to 1 compression.No problems.....My guess is without a true blueprint most 11 to 1 motors are hardly that.I would have been lucky to get 9 to 1 on mine.
Steve
Old 11-18-2005, 03:11 AM
I run the Jack Podell Lead/Octane additive in my soft valve seated L-78 Chevelle for years now.Just 12 oz. to every 10 gallons of 93 seems to agree with it.
She does run hotter though.
Old 11-18-2005, 03:13 AM
Rick...just pump some fuel out of your Sunoco Gas pump!
Old 11-18-2005, 03:48 AM
@wot @wot is offline
just curious how some of these l78 and l72 cars are tuned. i have 36 degrees of total mechanical advance in by 2750 rpm, no vacuum advance. i nee to mix race fuel to control detonation.
Dean
Old 11-18-2005, 12:33 PM
musclcar musclcar is offline
my camaro has an 11.5:1 350sbc and i run a mix of either VP MS103 or VP C12 with 91 octane pump gas.i can get all the race gas i need thru our race team and the price is right "FREE".ahh the smell of race gas coming from the exhaust of a healthy sounding street car
72 camaro ss 350 sbc 425hp old school day 2 build-up
Old 11-18-2005, 04:30 PM
juliosz's Avatar
juliosz juliosz is online now
I went through the engine on my 68 Z a couple of years ago. I went with all stock components except for roller tip rockers on my 302. I typically run about 10 gallons of 93 octane to 5 gallons of 110. Many times however, I run straight 93 with no detonation (total timing set to 36 degrees and running R45s). At first, I couldn't believe I could do this but then I read this article in Chevy Hi-Perf and it makes perfect sense to me. So those of you running hi compression + long duration cam may want to take this into consideration.
Old 11-18-2005, 05:33 PM
68l30's Avatar
Correct.....I run a high duration cam as well.If I remember correctly it's about 238 or 302 total duration.A lot of cam but very streetable with a 3800 converter and 4.10 rear.It runs very happy in the top end, 6500 +.....I get a little nervous up there though.....
Steve
Old 11-20-2005, 11:19 PM
70CitrusZ's Avatar
70CitrusZ 70CitrusZ is offline
My 70 LT-1 is built with pistons designed to produce 11 to 1 with 64 cc chambers.
Stock solid cam set at .024 and .026 lash
My decks were cut to clean up to parallel, about 7 thou.
I used head gaskets with a .039 compressed thickness.
Before I assembled heads, they were cylinder matched and laid back,and smoothed to eliminate hot spots. After that the chambers measured 61 to 61.5 cc.
I had hardened exhaust seats installed.
So far I have had no problem running 93 octane pump fuel.
Originally I fired it on 100 octane av gas, but found it ran cooler and still without detonation on unleaded 93.
Mark.
2012 ZL1 black M6
1968 L36 4 spd Biscayne
1957 270 hp Corvette
