Old 04-07-2005, 09:27 PM
Default Re: Valve caps
Clickable
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4541481754
Old 04-07-2005, 09:29 PM
Alss's Avatar
Alss Alss is offline
Default Re: Free Dill 627's
George I'll pick mine up when I see you on Tues.
ALbert
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 04-07-2005, 09:59 PM
MYSTERYCHEVELLE MYSTERYCHEVELLE is offline
Default Re: Dill caps
I don't have that latest issue or any issue for that matter, about the weights being installed ONLY on back of wheels.. can someone enlighten me as to WHY this would be the case... why would the factory care, assuming it was done for aesthetics reasons?
Mike
Old 04-07-2005, 10:06 PM
Because they would intefere with Trim rings mounted on the outside of the rim,if so inclined.
Old 04-07-2005, 10:18 PM
Rick
Was this "procedure" for all Bow-ties? or just Vettes? apply to spares too?
Thanks
Mike
Old 04-07-2005, 10:22 PM
I can't say for sure Mike.
I do know they didn't know what wheel was going to be a spare,so they would treat them all as if they were going onto the actual car itself.
I have a few books & a 1967 Uniroyal 16mm 60 minute movie,that shows the wheels & tires being assembled & static balanced.
I really don't know if different plants did different procedures.
Old 04-07-2005, 10:27 PM
Chevy454 Chevy454 is offline
Here is a short rundown of how one of the GM divisions did it (Oldsmobile) from Dave H, who was with Olds for a gabillion years...his thoughts were that each GM factory/division pretty much followed this procedure...
Factory balancing
All GM plants at that time used one weight to balance the wheel and tire assembly. Single plane, static balance. Hot wax was deposited in a color code to denote how much to put, and the tire was rotated and another yellow wax dot showed where to put it. You either got a 1/2 oz, 1 oz, 1 1/2 or 2 oz. Any more than that and the tire/wheel assy was rejected and replaced by another assy. Rejected ones were torn down and reassembled on another wheel/tire. Our main wheel and tire room at Oldsmobile Lansing ran at 600/hour in that time period, so that doesn't leave time to do split weighting like this tire/wheel. Some units were rebalanced with split weights in the audit area, so I guess I should never say never.
I think all the automakers used similar single plane equipment at that time (Micropoise, I believe), so my best guess is that is al old wheel/tire from a tire dealer. Toronadoes used dual plane dynamic balancing due to the huge offset in the wheel. That was done on another line.
My 68 came from the factory with Goodyear steel radials (an option on Cutlass, but not 442's) but they were defective and unsafe. Goodyear recalled all of them and gave a new set of anything you want just to get them off the road.
Old 04-08-2005, 12:39 AM
firstgenaddict's Avatar
Does anyone know what the color codes were for the wax?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 04-08-2005, 02:02 AM
Yellow?
Old 04-08-2005, 05:02 AM
KS Pontiac KS Pontiac is offline
Regarding the valve stem length discussed earlier,the normal short valve stem most tire stores use is called a TR413 or just 413 and is listed as 1 1/4 inches long in the dill catalog. From your description it sounds like the repro tires are coming with 418 valve stems which are listed as 2 inches long. There is a stem length in between the two called a 414 which is listed as 1 1/2 inches long but not all tire stores carry them. From the responces it sounds like some of you are on good terms with local tire stores and should be able to get them free or cheap. I usually sell them for .22 each but don't always have them on hand. Also I had my supplier get me a box of Dill 627 caps but it sounds like no one is going to need them now.I would be interested in how well the valve caps in an envelope go through the mail sorting machines.
