Old 01-03-2003, 11:47 PM
Default Re: Correct me if I'm wrong ............
Rob;
You found that style at the local parts store? That's where I'll go, let me know if you have a part number or a particular way of describing them to the 'Import Fanatics' that work at my local stores.
I won't say 'no' to seeing you guys at Norwalk, but I may run out of time to get the car dialed in - maybe I'll just use that as a test-n-tune, but wouldn't want to be embarassed if my stuff can't run a good number yet. This stuff is all new to me, I'm used to a hydraulic cam, quadrajet, and a/t = just stand on it all the way through the traps [img]/ubbthreads/images/icons/grin.gif[/img]
Old 01-04-2003, 09:40 AM
Casey Marks Casey Marks is offline
A hydraulic cam, a QJet, and an auto ....... and it's just *Stab-N-Steer*, 'eh ??? Hmmmmmmmmmmmmmmmmmmmmmm....... [img]/ubbthreads/images/icons/grin.gif[/img]
First spring clamps - THEN you guys are gonna start letting him know about Polyglas tire pressures ........ SHHHHHHHHHHHHHH !!!!!!
Old 01-04-2003, 12:38 PM
Sorry Casey, I should have added; 78 el camino 350, low compression, no cam, no tuning! Add to that a sleepy Th350 with shift kit, and an open end 3.08 geared 10 bolt. Plus, 145k miles on the stock suspension. It was a slow ride, but a fun time.
Don't worry, I know who won the battle of the small block in MCR - where was Pete and JJ on that day [img]/ubbthreads/images/icons/grin.gif[/img]
Old 01-04-2003, 01:45 PM
moparts moparts is offline
Robs local parts store is pretty special if I do say so myself. [img]/ubbthreads/images/icons/grin.gif[/img]
Mr. G. 1293
20 foot 75 hp good time at the lake
Old 01-04-2003, 01:52 PM
Default WHAAAAAAAAAAAAAAAAAAT ?
Marlin,
If it didn't have a camshaft in it - it needed one. We'll work from there.......... [img]/ubbthreads/images/icons/shocked.gif[/img]
Old 01-04-2003, 03:46 PM
Chevy454 Chevy454 is offline
Default Re: WHAAAAAAAAAAAAAAAAAAT ?
<blockquote><font class="small">In reply to:</font><hr>
Mr. G. 1293
<hr></blockquote>
There you go, M! It's nice having your parts man online!
Old 01-04-2003, 03:50 PM
Thank you gentlemen!
Casey, allow me to rephrase [img]/ubbthreads/images/icons/grin.gif[/img] 'The cam was not a hi-performance cam'. I drove it back and forth to college, so I guess it had some kind of broomstick in there, [img]/ubbthreads/images/icons/confused.gif[/img] it was a fun car, but it had to go!
Old 01-04-2003, 05:47 PM
John Brown's Avatar
Marlin, I'm sure Copo Pete and Jimmy J. have lots of experience behind the wheel of a 4 gear LT-1 Nova, and would probably be glad to give your b-e-i-g-e car a few shakedown passes. You know, just to make sure its safe and all like that. [img]/ubbthreads/images/icons/wink.gif[/img]
John Brown
Old 01-05-2003, 02:31 AM
Let's tell Marlin that he needs 25PSI in the rear of the WideOvals .......... and 30 in the front .......... come ON, I CAN'T have an LT-1 Nova spank me ..............
Well - OK, maybe ..... b e i g e is the insert color on my Ford dually .......... [img]/ubbthreads/images/icons/grin.gif[/img]
Old 01-09-2003, 11:58 PM
Default OK - I'll be kinda nice .......
Marlin,
With these tires, the trick is to not blow them away coming out hard.
For example: With my W-31, I have a $53 reman'd Dynamic converter that seems like it is about 15" in dia. It lugs the motor enough from a "dig" that it allows the tires enough time to bite before the motor "comes on". I also run a LOT of advance in the distributor. Basically - off-idle, it is at full advance, which also helps the low end.
OK - THAT's it from the Olds Corner !!!!! [img]/ubbthreads/images/icons/grin.gif[/img]
Marlin's a scardey-cat to race his Deuce ......
Hey Marlin - My W-31 went MID-15's it's first year out. Don't worry 'bout it dooood.
Marlin's still afraid an Olds may beat his lil'ole Nova .... [img]/ubbthreads/images/icons/smirk.gif[/img] [img]/ubbthreads/images/icons/smirk.gif[/img]
