Old 10-22-2002, 05:41 PM
moparts moparts is offline
Default Re: COPO Chevelle trim tag data
Question??? Does the build sheet of most cars have the vin # on it or the body #???? [img]/ubbthreads/images/icons/confused.gif[/img]
20 foot 75 hp good time at the lake
Old 10-22-2002, 06:00 PM
Chevy454 Chevy454 is offline
You'll love this answer Mo: BOTH! [img]/ubbthreads/images/icons/grin.gif[/img] Although, the body number was in larger print I believe, for whatever reason (different machine thus different font, more importance, etc., any other ideas?).
Old 10-22-2002, 07:05 PM
Mark_C Mark_C is offline
Body numbers were assigned when the Order was accepted for build, VINs were assigned (at least for Camaros) when the body was actually scheduled for building That may be the day before, or the week before actual construction. TRIM tags and VIN tags were prepared at the same time, TRIM Tags by Fischer, VIN's by Chevrolet to coincide with production of the cars. VIN's and Body numbers are both listed on Chassis broadcast sheets.
Mark C.
My Pace Car
Old 10-22-2002, 09:27 PM
sYc sYc is offline
COPO; The VIN would have to be assigned before the car began production, because the VIN is stamped on various areas of a car's sheetmetal, cowl for Camaro, Firewall for Nova. There is no doubt that this had to, and did occur in the Fisher Body "body shop", the 1st phase of building a car. If Chevrolet did it, A. it would be next to impossible to reach the area, and B. they would be working on freshly painted sheetmetal. Tom
Tom Clary
Old 10-22-2002, 09:40 PM
It looks like I may have gotten ahead of myself. I have some 03x dated cars, and I can't seem to make them fit into my "formula", which is odd, becuase the later cars fit darn near perfect...so where did I go wrong?
Old 10-22-2002, 10:31 PM
copo9566aa copo9566aa is offline
3 289XXX boby = 3 special paint. [img]/ubbthreads/images/icons/cool.gif[/img]
Just a remark.
Old 10-23-2002, 02:55 AM
Ed Cunneen Ed Cunneen is offline
Tom,
I believe the VIN stampings were done at the Chevrolet plant, not at the Fisher Body Plant. For instance, the Camaro front fenders were painted off of the car and would join up after the VIN was stamped in the two locations. I have a picture of a '71 Firebird at the Norwood plant without subframe or front end coming down the assembly line.
Old 10-23-2002, 03:36 AM
Tom,
This may help clarify things. I just recently re read the Nova Times series from several months in late 1993 on the Fisher body side of the Willow Run Plant. Several Willow Run key employees were interviewed. It ran through the build sequence in generic detail covering the many years Novas were built. It a generic sense it might help this thread since GM probably did similar things since the build sheets, trim tags, VIN plates are similar between Chevy's. In a few words here are the highlights. (This summary does not do the series justice! Forgive me if I am a little too basic here and by all means pick it a part! [img]/ubbthreads/images/icons/tongue.gif[/img] )
Body flow was controlled by the SEQUENCE (my emphasis) number based on the Production Schedule generated by the Data Processing (computer) department and published days in advance of the day the body was started. This controlled the "Body Shop Order of Run" which determined how many of each body type was put on the line and in what SEQUENCE. Body styles and options were distributed so as to not have 20 AC cars in row. It took longer to install AC than just a heater. The amount of time to install all of the options was determined by the speed of the line. Options were spread through out the production schedule to keep the line moving. Color was also a concern. The Body Shop Order of Run list creates a SEQUENCE number. As the body starts down the line the operator took a floor pan and marked a 4 digit SEQUENCE number in crayon from his copy of the "Body Shop Order of Run" onto it . Later as the body moved down the line a Fisher Body build sheet matching the crayon number was taped to the body. The sheet listed body style and options needing different body parts.
Until now the crayon number identified the body. If the Fisher Build sheet was lost, the crayon number ruled. As the completed body reached the Scheduling Clerk's Station the clerk checked the crayon number against the build manifest. The clerk matched the number to the last 4 digits on a trim tag which was already stamped with the BODY number. The clerk would then place the trim tag into the stamping machine. He added trim, paint and date codes. So the date code reflected the week the body was welded together. Since the body was not painted, the date code might be an earlier week than assembly week indicated on the VIN label.
The Scheduling Clerk was also responsible for the VIN. He took the VIN shown on the manifest and passed it to a portable stamping machine operator who dialed it into his machine. This was how the hidden VIN was stamped on the body. The VIN was probably assigned by computer, but this was not discussed in the article. So this is the missing piece of the puzzle.
The interior and exterior paint code was marked on firewall prior to painting. Willow Run BATCH painted cars. So regardless of the body number all red cars were pulled aside waiting their turn at the paint booth. At this point the body SEQUENCE number of the trim tag no longer mattered. As bodies moved through the rest of Fisher Body there we assigned a NEW SEQUENCE number at various stages. That is why the SEQ number on the Fisher Body sheet does not match BODY number or VIN. A body might have many SEQ numbers during the build process. A new SEQ was assigned by GM after the body passed thought the wall.
The function of the BODY number was only the original SEQUENCE number for the body. Since COPO cars were all built the same, Data Processing (the computer) probably distributed them though the Production Schedule. Having ALL of the COPO cars in a row probably did not happen. If a part was not available and the computer knew it, the body would not be scheduled to be built. If a shortage was found on the line the body would be pulled off. Pulling a body of the line was very bad.
Cars moved through the plant like ants at a picnic. SEQUENCE number was used to control the flow not VIN or Body Number. This explains why neither VIN nor Body Numbers are in date sequence.
Greg (sorry for the length. The fewer words I used the longer the message. [img]/ubbthreads/images/icons/grin.gif[/img]
Old 10-23-2002, 11:13 AM
COPO COPO is offline
Great info!
Old 10-23-2002, 12:57 PM
Jeff H Jeff H is offline
My broadcast sheet has a sequence # on it and I found that sequence # written on the firewall behind the driver's side fender. But it's a 3 digit sequence # on the Camaro. My car is an LA car though so they might have done things a little differently.
