Old 01-19-2021, 10:49 AM
kwhizz kwhizz is offline
LOL.....Just wiring for the Vintage Air unit in white mesh shielding ....
Old 01-19-2021, 10:50 AM
It's looking better now....... If Possible....LOL
Old 01-23-2021, 03:24 PM
Update....... Pretty much finished except for the Hydra-Boost system which hopefully will be here next week......... Got the wiring under the dash under control.... LOL.... The steering column cable shifter is adjusted and works perfectly..... Gas Pedal installed and hooked up....Under hood wiring all cleaned up.....One of the big surprises is the new Dakota digital features now available is the programming of the fan controller module using a Blue Tooth app.......So easy and simple..... one of the past concerns with these modules is having access to them for changing the settings....... Not required anymore.... Bury it in the dash with no concerns for access...... Great Job Dakota !!!!!!Got the dash installed and the new gauges .....Too Simple.....the Neutral Safety switch is now controlled by the Dakota gear position indicator....... Hit the key and everything works as it should..... Didn't want to start the engine yet as the power steering pump is not hooked up yet and don't want to ruin it......
The Following 3 Users Say Thank You to kwhizz For This Useful Post:
dykstra (01-24-2021), olredalert (01-23-2021), PeteLeathersac (01-23-2021)
Old 01-23-2021, 03:27 PM
----Does the knee knocker tach still work?.....Bill S
Old 01-23-2021, 03:41 PM
Looking awesome Ken!!
Old 01-23-2021, 08:21 PM
I still need to figure that out.
Old 01-23-2021, 10:01 PM
Done..... Just waiting for the Hydra-Boost now !!!!
The Following 2 Users Say Thank You to kwhizz For This Useful Post:
dykstra (01-24-2021), Xplantdad (01-24-2021)
Old 01-23-2021, 10:56 PM
Now, you have a complete LS Shop.
Well done!
Fast forward to 20 years (2041)....your son will be repeating your exact same process and footsteps....only this time....the LS engine will be replaced with Electric Motors....with all wheel drive 2000 hp....with batteries the size of an Iphone.
The Following 2 Users Say Thank You to Postsedan For This Useful Post:
kwhizz (01-24-2021), markinnaples (01-26-2021)
Old 01-24-2021, 10:36 AM
Well done!
Yep !!!!....... All part of the Green New Deal !!!!!!!
Old 01-24-2021, 02:11 PM
Looks awesome as always, Ken!
