Old 06-27-2016, 12:34 AM
Pusher_Man Pusher_Man is offline
Default Re: 67 - 68 chevy II restorer
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PeteLeathersac</div><div class="ubbcode-body">-
Are you saying Muncies and Sag's were both supplied w/ the dozen or so/whatever actual '67 L79 production was?
Also, is it known specifically that all '67 L79 production were 2-Dr. Hardtops or any 2-Dr. Sedans possibly built/existing?
Lastly, what of any '67 Acadian L79 cars...built/not/body style/known?
Cool subject!
~ Pete
</div></div>
only saginaws were used in them, which adds to their uniqueness.
all of the L79 Chevy II's were Nova SS cars.
yes, very cool subject. from what all I've researched they were all:
Nova SS cars
cast iron intake (vs aluminum in 66)
quadrajet carb (vs holley in 66)
325hp (vs 350hp in 66)
open air element (vs double snorkel in 66)
saginaw 4 speed trans
may or later builds
FQ coded only rears, which is 3.07 12-bolt open (GM literally only made that rear for this car)
these cars are so interesting (and not because i have one), but because they are like an in between model of their own...stuck between a 66 look and a 68 engine with the open air cleaner, carb, and cast intake, but yet with a diff trans and unique rear. they almost appear to be an experiment or something crazy. it used to be supposed that the 6 engines were leftover blocks from 66, but then they didn't make the cars until the end of the model year so who knows about that? although they might have been. i'd love to know the cast date of an original engine car, to see if it follows the normal rules of within 2 or 3 months or so, or if it literally was leftover from the 66 ones.
mine unfortunately doesn't have its original block. it does have a 68 CE block. i tracked down the original owner from the pop and he told me a service station messed a valve cover up or something and caused the oil to leak out and locked the engine up. he said they then got a replacement for it. man, it is always the coolest thing in the world to talk to an original owner of any classic car. always a big treat of mine.
Old 06-27-2016, 12:39 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: John Brown</div><div class="ubbcode-body">Engine picture from same car. </div></div>
oh, and john, thanks a lot for posting pics of that car. i believe its the same one I've seen on the nova site before, along with a yellow car that is supposedly documented as well.
where did you see that car at?
Old 06-27-2016, 12:57 AM
67 Nova Boy's Avatar
67 Axle codes...
1967
BA - 3.08 open 10-bolt
BC - 3.36 open 10-bolt
BE - 3.08 posi 10-bolt
BF - 3.36 posi 10-bolt
BG - 3.55 posi 10-bolt
BH - 3.55 open
BQ - 3.31 open 12-bolt (327 Special Hi-Per - A/C)
BR - 3.07 posi 12-bolt
BS - 3.31 posi 12-bolt
BT - 3.07 open 12-bolt (metallic brakes)
BU - 3.07 posi 12-bolt (metallic brakes)
BV - 3.31 open 12-bolt (metallic brakes)
BW - 3.31 posi 12-bolt (metallic brakes)
FI - 3.55 open 12-bolt (close ratio 4 speed)
FJ - 3.55 open 12-bolt (metallic brakes)
FK - 3.55 posi 12-bolt (metallic brakes)
FL - 3.55 posi 12-bolt
FM - 3.73 open
FN - 3.73 open (metallic brakes)
FO - 3.73 posi (metallic brakes)
FP - 3.73 posi
FQ - 3.07 open 12-bolt (327 Special Hi-Per)
Old 06-27-2016, 01:24 AM
^^^^ yep, thanks for posting that.
thats how my car was discovered...by its rear code. the guy i bought it from was looking for a solid 67 nova ss to tub out and hot rod. thankfully he stopped before he got started and looked up the rear and then the pop engine code and then about crapped his pants. thats a pretty cool story by itself.
Old 06-27-2016, 01:36 AM
These are Delco Harrison Radiator books that show the 67 Nova 327/325HP... so just another clue that they were real deal cars. Does your car have the original Radiator with finger guard?
Dave
67 Nova Boy
Old 06-27-2016, 01:49 AM
Also...here is a 67 dealer order form 5/4/67 that does not show any 325/HP to order so when was this on a dealer order form if ever and how did they know there was any to order? Did they just come in that way and was ordered by salesmen or special order?
Dave
67 Nova Boy
Here is a 66 L79 327/350HP on a 66 dealer order form.
Old 06-27-2016, 02:57 AM
John Brown's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Pusher_Man</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: John Brown</div><div class="ubbcode-body">Engine picture from same car. </div></div>
where did you see that car at? </div></div>
I've never seen the car in person. Had a friend send me the pictures back in 2009 cause he thought I would find them interesting.
John Brown
Old 06-27-2016, 11:40 AM
great info NovaBoy.
Old 06-27-2016, 11:46 AM
If you look closely at the radiator listings you will see the 396/325hp listed for the 1968 Nova...that engine was never available in the Nova.
wilma
Old 06-27-2016, 11:55 AM
cook_dw's Avatar
cook_dw cook_dw is offline
Jack Duer's old L79. (Same car as above). Pretty sure I remember someone saying Jack sold his car to Dan Miller which at the time was the only other known L79.
http://chevynova.com/gallery/index.php?g2_itemId=2976
Kasey, are you driving the Chevy II down to the SCR? I would like to take a look at it if you do.
