Old 12-30-2008, 01:02 AM
bkhpah bkhpah is offline
Default Re: Need some Critique on my 69
The Delco Morane stamping on the power boosters I have seen are all over the board. From very faint stampings to none at all. I have also seen the DM logo in the 2 o'clock position on unmolested low mile cars. While, not typical, they are made that way. Just like the differences in font size in the date and application code. Just to many variables during the model year to say it could only be one way. Also the pinch clamps on the PCV valve should have squared off ends. The kind that rip your finger's open square. Later style pinch clamps used a rounded end. Much more finger friendly..BKH
Old 12-30-2008, 01:15 AM
firstgenaddict's Avatar
I have seen the larger style upper control arm shafts with the nut on the A bodies before...
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 12-30-2008, 01:45 AM
Jerry@CHP Jerry@CHP is offline
Banned
I have never seen any large nut shafts on any survivors or cars that I've known going back almost 40 years. Those large nut shafts were swapped out many times in the 1970s for added front end alignment adjustments.
Now that these cars are 40 years old, it's almost impossible to document one unless it's an original owner car or two owner car.
Jerry
Old 12-30-2008, 02:15 AM
JoeG JoeG is offline
I have those large nuts on my '69 SS 396 Chevelle--(I'm the original owner) natural metal color........
Old 12-30-2008, 02:26 AM
Banned
Joe,
I was an original SS396 Chevelle owner until 1993. Yours would be the first that I know of.........what plant was it built?
Jerry
Old 12-30-2008, 02:43 AM
Framingham,Mass.----late May'69..
Old 12-30-2008, 02:45 AM
Jerry... This is the car Joe is talking about!
Old 12-30-2008, 02:48 AM
Banned
Mine was a Baltimore car. I'll have to check the parts books and assm manual to see what is called out. Hard to believe that this would be a plant variation. All Kansas City cars that I've seen are like the Balto cars. All Camaros built at both assm plants are the same with large washers and 5/16 bolts.
Jerry
Old 12-30-2008, 02:53 AM
Banned
Bruce,
A one owner Motion SS Chevelle with docs. Wow! Not many around like this I'm sure.
Joe, did you ever race this car? I grew up 15 minutes away from Motion in N. Massapequa. Used to go over there when I was just barely a teenager. It was a happening place back then.
Jerry
Old 12-30-2008, 02:55 AM
Unless Motion swapped them out when front spring lifts were put in............
