Old 08-30-2007, 04:49 AM
Default Re: 72 T/A progess
Awesome stuff Steve...er, McGyver!
Old 08-30-2007, 05:28 AM
kwhizz kwhizz is offline
Steve...........Great Job........
Ken
Old 08-30-2007, 07:12 AM
MosportGreen66's Avatar
That is awesome stuff Steve! A true inspiration for the do-it-yourself-er...
Old 08-30-2007, 08:04 AM
mockingbird812's Avatar
Holy Cow Mac !!!! You've done it again. Thanks for the inspiration.
Sam...
Old 08-30-2007, 07:50 PM
Ngtflyr Ngtflyr is offline
All I can say is "WOW"
Dave
Old 08-31-2007, 06:28 AM
Since the guys over at the Performance Years website thought the spokes were a little too light when compared to some low mileage reference photos, I modified the washing technique a little, once again resorting to my old military modeler days. I employed another wash technique using my wife's black acrylic stenciling paint and water and the same foam brush over the prior enamel washing. I applied about 15 coats over the course of the afternoon and then, once it dried, sprayed some clear Rustoleum spray paint over it from about 3 feet away so it was almost dry when it hit the wheel rims.
The comparson photo used for color reference purposes was from a late 71 Formula.
Old 09-01-2007, 07:24 PM
Being the tinkerer that I am, I decided that the finish on the rubber rim was a little too flat so I used a can of the black Plasti-Dip Rubber Coating Spray and sprayed several coats on the rim. That stuff is amazing. It leaves a nice rubbery semi-shiny finish on the surface that duplicates the original foam rubber finish perfectly, and I had no problems with spraying the coats immediately after one another even though the can says wait 30 minutes between coats. I think they mean if you stop spraying, and let it sit for more than a minute, it may craze the previous layer. So, I ended up just spraying continuously to fully cover all surfaces of the rim. I then just left it to sit overnight. Here is the result from this morning.
Old 09-01-2007, 07:29 PM
Quit your day Job.
Old 09-01-2007, 08:50 PM
That's so beautiful, I'd wear it as a hat.
Sam...
Old 09-01-2007, 11:27 PM
I was thinking more along the lines of a broach, or maybe get another wheel and try them on as two "pasties" for the more daring ladies out there!
