Old 10-25-2012, 12:13 AM
firstgenaddict's Avatar
Default Re: Day 2 parts discussion
Did the duocoil fire the plug 180 deg in rotation from the cylinder on the power stroke (2 plugs being fired)?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 10-28-2012, 05:10 AM
C1SS396 C1SS396 is offline
EELCO COOL CAN
NOS BLUE Flex fan
I am out there finding it so you don't have to .
Old 10-29-2012, 01:22 AM
Nova Jed Nova Jed is offline
NOS BLUE Flex fan
[/quote]
You know I love that fan!
Old 10-28-2012, 06:06 PM
mockingbird812's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: firstgenaddict</div><div class="ubbcode-body">Did the duocoil fire the plug 180 deg in rotation from the cylinder on the power stroke (2 plugs being fired)? </div></div>
Looks like you have one coil, two condensers, and two sets of points (each set of points has a dedicated condenser). Most likely the coil charged up each of the two condensers and they both discharged simultaneously, one to each set of points. The rotor then sends the combined hotter spark to a single plug electrode.
Really like the cool can. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Sam...
Old 10-28-2012, 09:34 PM
PxTx's Avatar
PxTx PxTx is offline
I was kinda scratching my head on the rotor with two discharge points too. I remember my Dad ran a 312 with a Paxton in the mid 1960's that he said had twin ignition systems. Turns out it had a Ducoil running 2 coils, which he said seemed to require frequent cap changes due to misfires.
In a similar way to the Mallory Double Life, the Ducoil would alternate the points. Since they used 2 coils, it gave them more saturation time. The key was that you had to reconfigure the plug wires. So if you were running an engine with a 1-8-4-3-6-5-7-2 the new cap configuration would be 1-5-4-2-6-8-7-3. Neither of us knew that off the top of our heads. Needed to to sketch the cap and distributor rotation on paper, so I think it's right.
If I find any old pictures of the 312, I'll be sure to post them.
Paul III
Old 10-29-2012, 04:23 AM
wheelhop wheelhop is offline
Ansen Bellhousing for Chevy
Old 10-29-2012, 01:45 PM
Hemicolt Hemicolt is offline
What's up with the aluminum spacer?
It's not the critic that counts, not the man who points out how the strong man stumbled or whether the doer of deeds could have done them better...
Old 10-29-2012, 03:46 PM
Fast67VelleN2O's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hemicolt</div><div class="ubbcode-body">What's up with the aluminum spacer? </div></div>
I've never seen one with a spacer ever and I have owned a lot of those Ansen bells in the past.
Day 2 is Life.
Old 10-29-2012, 05:00 PM
Never seen one either. I can't imagine it would have been added in order to run a larger dia. clutch. It would have hit at the top anyway....yes/no?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Fast67VelleN2O</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Hemicolt</div><div class="ubbcode-body">What's up with the aluminum spacer? </div></div>
I've never seen one with a spacer ever and I have owned a lot of those Ansen bells in the past.</div></div>
Old 10-29-2012, 06:29 PM
396L35's Avatar
396L35 396L35 is offline
It is for the 11&quot; flywheel. The top has the clearance the the bottom cover hits that is where the spacer comes in handy. This wasn't a factory piece but fabricated to avoid issues.
Mark
