Nice trouble shooting on the Primary lead wire.Was just talking to someone about your camaro and couldn't find this topic.
Thanks for bringing it back to the top. |
| The Following User Says Thank You to Mr70 For This Useful Post: | ||
jbtech (03-08-2025) | ||
X2!!
https://www.youtube.com/watch?v=gkDf7PPRzJ0 |
| The Following User Says Thank You to BJCHEV396 For This Useful Post: | ||
Finally got around to adjusting the tach. I removed the driver seat, laid on my back with my head/arm behind the dash. With a small screwdriver I adjusted the tach and this is best I could get it. From idle to 2000rpm it reads around 150-200rpm too high but from 2000-7000rpm it's dead on. Prior to adjustment, when I was cruising at 2800rpm the tach would read around 3500rpm. The tach photo is when receiving a 3000rpm signal.
I also mocked up the line lock button. |
| The Following 6 Users Say Thank You to jbtech For This Useful Post: | ||
1967 4K (03-09-2025), cheveslakr (03-12-2025), dykstra (03-08-2025), L_e_e (03-08-2025), PeteLeathersac (03-08-2025), Steve Shauger (03-08-2025) | ||
How were you able to adjust the tach needle?
Jason's advice and photo from post 270:
With all of that said the tach needle itself when the car is off rests about 100-200rpm too high, but since my readings were accurate from 2000-7000rpm after adjustment it was fine by me. |
| The Following 9 Users Say Thank You to jbtech For This Useful Post: | ||
169indy (03-18-2025), 1967 4K (03-09-2025), big gear head (03-10-2025), dykstra (03-09-2025), napa68 (03-10-2025), olredalert (03-09-2025), PeteLeathersac (03-09-2025), ragtop (03-09-2025), scuncio (03-10-2025) | ||
Jose,
Did the tach always “zero” At 100-200 or was that after the adjustment. Moving the potentiometer shouldn’t affect the zero reading. I love the chrome line lock button. Fancy! Jason |
| The Following User Says Thank You to SuperNovaSS For This Useful Post: | ||
169indy (03-18-2025) | ||
To clarify the tach never did rest at zero. The adjustment did not alter the resting position but it did make a huge improvement in the overall accuracy of the tach. Here is a photo of the tach off/zero rpm.
Here is my draft wiring diagram that will allow me to use the chrome lineloc button in traditional fashion for burnouts.
With the flip of a switch however, I can depress the clutch and hold the brake, the chrome button will only need to be pressed once, and will engage a latching relay that will hold the line loc and launch rpm limiter on the Omex clubman. When the clutch is released it will disengage both the line loc and launch rpm limit. The omex clubman has 2 wires coming out of the box which connects to a normally open switch, when the circuit is closed it activated the 2 step. Other systems simply use a 12 volt feed. Anyway this is the reason for the 3rd relay. |
| The Following 3 Users Say Thank You to jbtech For This Useful Post: | ||
| Tags |
| 1967, 396 ss, l78 camaro |
