Old 11-13-2006, 03:51 AM
Pacecarjeff's Avatar
Pacecarjeff Pacecarjeff is offline
Default Re: L78 VIN stamp photos
Jeff, neither are restamps. I pulled both the engine and trans myself and both have different fonts. I think I may have to contact CRG on this one. I know everyone is thinking, how do you know they are original stampings? They are and I can prove it. Strange....
There are always exceptions to the rule.
I am sure CRG would like to see the pictures, and hear your story.
I would imagine that there are 1000's of "not typical" original stampings out there.
This was done on a fast moving assembly line, and the guy doing it - used a big hammer.
Old 11-14-2006, 12:57 AM
elcamino elcamino is offline
The harder the stamp is struck, the deeper the impression and the larger it will look. If not struck perfectly at 90° to the block, one end could appear larger than they other end.
NEW cars I had..
66 Impala SS396
70 Chevelle SS 454
72 El Camino SS350
73 Chevelle SS350
Old 11-14-2006, 08:30 AM
Kurt S Kurt S is offline
Are you sure the trans and engine were always stamped with the same gang stamp? I have seen more then one example of legit vin stamps where the fonts (6's and 9's) on the block and transmission were different. Can this be explained?
There's the outside chance it could have a in-plant repair that required a new block or trans (and hence a VIN stamp on the new component). But these happened very infrequently.
They should match. I've seen lots that don't, cause one was stamped years later....
Kurt S - CRG
