Old 01-12-2006, 04:59 AM
sean70ss sean70ss is offline
Default Re: 70 RS Z28
Looks like a pretty darn nice car! Sean
Old 01-12-2006, 11:31 AM
redbaron redbaron is offline
Should it have the year number before the N Rick?
Mike
69 SS 396 Camaro
69 RS/SS Camaro
69 LS2 T56 Camaro
69 Ls7 T56 Camaro Project
Old 01-12-2006, 05:23 PM
Rick H Rick H is offline
Yenko Premier Member
Already mentioned in post above.
The car is still very nice and you don't see many in that color combo.
mmmmm, maybe I should just get a completed car and forget about the project Z I have in my driveway. Naa, that's no fun.
Rick H.
Old 01-12-2006, 05:29 PM
So if the vin stamp has been added to the deck..Is there a chance there is still a vin stamp down by the oil filter ? I haven't looked at enough 70's to remember.
Old 01-12-2006, 06:54 PM
COPO427 COPO427 is offline
yup, your correct, the same goes for in the heater core box.
1970 Norwood Z28 M22, 3.73, Z21, Z87, TR 725
Old 01-12-2006, 06:57 PM
yes
Old 01-12-2006, 07:50 PM
1)Has it been determined on THIS Yellow Norwood Z-28 that it has a 10N5xxxxx VIN number stamped on the Bellhousing Flange to match the alledged 10N5xxxxx on the transmission.
2) Has it been concluded that more than a few other Norwood 70 Z's had VIN # stamped on eng deck. I will ask most of the other 70 Z judges and "experts" at nastyZ28.
3)WHY would a born with eng with VIN stamp, NOT match the VIN stamp configuration of the Born with Transmission......IF in fact they are done with same stamping tool??????
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 01-12-2006, 10:42 PM
70 Camaro VIN will start with 124870N.....
Muncie Example
70N553721 P0E08B
70 = 1970
N = Norwood
553721 = the last 6 digits of your VIN
P = Muncie
0 = 1970
E = May
08 = day
B = M21 (A=M20, B=M21, C=M22)
Axle will be C00 or CRE for a 4.10 (last yr for 12 bolt)
Engine pad will have:
Example: V0101CTB - (V = Plant, 01 = Month, 01 = Day, CTB = Engine Suffix Code),1970 CTB 350 Z28.
Also a partial VIN will be on the pad, IE 70N123456
Both tranny and engine will have the same 6 digit VIN as seen on the dash.
Old 01-12-2006, 11:00 PM
PeteLeathersac's Avatar
I think CamarosRus' question means, the stamped locations should have the same alpha numerics and number of digits since they were stamped at the same time using the same gang stamp....all EXACTLY the same. . So a genuine factory stamping mistake would be on all locations? . ~ Pete
Old 01-12-2006, 11:03 PM
The partial VIN will be a smaller stamp text size.
70N123456
