Old 08-25-2005, 01:11 AM
rangelec rangelec is offline
Default Re: WOW! Check out this buildsheet.
I owned a 70 Chevelle SS396 back in 1979-had 2 buildsheets in the same place as this one. Even back then the sheet was yellowed! I took one before I sold the car for $550-still have one copy of the build sheet though! Bought it in 79 for $600 and drove it for a year and sold it for $550. 396 350 hp bench seat 4 speed with 3.31 12 bolt-all cowl stuff was there along with lots of rust.
Old 08-26-2005, 05:26 AM
scott s scott s is offline
Have a all orig kansas city built 69 chevelle ss iam looking for the chasis build sheet where should i look??I have the body broadcast sheet and found the attached sheet behind the pass seat back but do not know what it is .Already looked under rear seat ,did kan use the sheets like la cars did?????
Old 08-26-2005, 05:27 AM
sorry wrong pic to many build sheets
Old 08-26-2005, 06:06 AM
Here is the entire sheet ,i have never seen one before???
Old 08-26-2005, 06:53 AM
That's a seat trim sheet.
Try looking for the buildsheet behind the door & rear panels-behind seat backs-under package tray cardboard-inside Headliner & ear muffs-under both Ft. & Rear seat buns-top of Gas tank-under carpeting-under floor sound deadner-under the dash & dashpad-taped to top of the radio-kick panels-engine the compartment wheel wells to fender area too.
Old 08-26-2005, 07:16 AM
Thanks ill check those areas ,i have the body broadcast sheet which was found in the front fender well area and looks like one from a la built car.Will the build sheet be cut in half like the rest that i have seen posted here???
Old 08-26-2005, 07:30 AM
I haven't seen any Kansas Leeds Plant Buildsheets cut in half.
Framingham Mass. plant is where some were razored into a 1/3rd during seat construction.
