Old 09-10-2005, 04:10 PM
Default Re: 1968 CY Trans details
I'd buy it for that.
What's the VIN# stamped into the machined pad on the drivers side,just above the shift linkage behind the rubber boot?
Can you read the Pass. side aluminum tag as well?
Old 09-11-2005, 06:38 AM
rangelec
I wanted to reply to your question in the 6-lug convertor thread about this TH400,so I thought this topic was better.
The 1970 CW is a seldom seen scarce Transmission.
1970 CW TH400 was designed for specific Solid lifter BB & SB Applications.
They were:
*Chevelle-Nova-Camaro L-78 402/375HP.
*Camaro Z/28-Nova LT-1 350/360HP Yenko Deuce.
Not knowing it's overall condition,I'd say it's worth the 1K regardless.
Old 09-16-2005, 09:27 PM
I have the CW coded trans in my 70 Z28. What is different about this transmission over a CX or CY tranny and any other unique features. It also has the 6-bolt converter.
Paul
Old 09-18-2005, 06:07 AM
oramac68 oramac68 is offline
Hello everyone, I'm confused, which one would go in a 69 Camaro or Chevelle L-78, a CW, CY , CX or CC? , Thanks
Old 09-18-2005, 09:46 PM
1969 Camaro & Chevelle used the CX TH400,as well as other solid lifter applications.
1970 was new for the CW suffix TH400,in the L-78 & LT-1 Camaro-Nova-Chevelle.
Old 10-14-2005, 08:26 AM
fpcopo fpcopo is offline
To Wilmasboy:
My research has said that the design upshift speed at WOT of the 69 CY trans was 5900 to 6100. The high speed governor will help you up your shift points but also affecting shift timing are line pressure and accumulator springs and pistons. Also the trans was designed for hard use as all wavy shift plates from clutch packs were removed for harder as well as quicker shifts. Some other mods were the forward clutch drums have 2 oil bleed check balls instead of 1, this allows oil to dump faster to speed shift timing. The 6 lug convertors were first used in trucks so you can find trucks with the same convertor shell but everything inside is vastly different. Frank
Old 11-15-2005, 03:18 AM
Michael4yah Michael4yah is offline
Would you happen to have the list for the 68's
Old 11-15-2005, 11:25 PM
Chevy454 Chevy454 is offline
I believe it's gonna be the same...except the converter is different, which according to Ray Morrison flashes in the ~1800 rpm range...
Old 12-17-2005, 03:35 AM
JohnZ JohnZ is offline
Here's the tag on a "CY" in a neighbor's all-original '71 LS-6 Corvette:
'69 Z/28
Fathom Green
CRG
Old 01-04-2006, 08:54 PM
Frank,
I recently found a 69 CX THM400 out of an L/78 Nova. I now
need the correct 6-lug converter. I see them on eBay from
time to time, but you comment about the truck converter
being vastly different concerns me. How does one know if
you have a true SHP 6-lug converter? Or, are they still
available from GM with the proper internals for an L/78?
BTW, were the SHP converters stamped or coded in any way?
Steve
