Old 11-26-2004, 10:15 PM
bilede bilede is offline
Default Re: Barn filling up...shoulda built a bigger one..
now ya tell me, I just finished 50'
Old 11-26-2004, 11:32 PM
Pantera Pantera is offline
I built a 50 x 60 and wish it had been wider for sure. If you come down I-44 through Tulsa give me a call and I will show you the problem with that narrow of a building in person.
You will need to angle park them in some, or else it takes too long to get them out. Otherwise you can't have any storage on the walls in front of the cars.
What ever you do, don't let anyone talk you into spray-on insulation on a steel building.
70 BM Phase III GT Vette
69 BM SS427 GT vette?
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 11-26-2004, 11:34 PM
HeY !!!!! I was gonna see about spray on in my old barn....What is wrong with it ?
Old 11-27-2004, 09:28 AM
resto4u resto4u is offline
I would think the spray foam ins. would get old and start leaving dust all over your cars.
Old 11-27-2004, 10:32 AM
I was thinking of spray foam and then tin the inside . The reason for the foam is it would seal up the building pretty good.
Old 11-27-2004, 11:57 PM
I was thinking foam also but here with the heat someone said there is a thermal barrier paint that would work well. anyone ever used it? the foam on roofs does start dusting off if not painted/sealed periodically.. not sure if its inside..
Old 11-28-2004, 12:00 AM
I don't see a problem if it is covered and sealed. They use it in new houses and use a hand saw to level it with the framing and then put on there drywall. Roger
Old 11-29-2004, 06:34 AM
On a house where you use wood framing and a plywood deck for the roof it is great.
BUT: On a metal building I have seen it happen too many times that the tempature difference between the inside and outside is too great. the inside will sweat and condense on the underside of the metal. It will cause the insulation to delaminate from the metal as it gets older and fall off in big chunks.
Seriously guys, I have seen it happen with my own eyes. It is not a thing you want to happen. Kind of like my skylights in the roof of my building. Dam things will drip when the temp difference is too great.
One of my good friends built a flat top raised seam roof on his 6,000 sf building with Tilt up concrete walls. After it was finished the supended celling was ruined by water leaks that they could never seem to find.
Two years later they finally went back to the manfacturer and raised hell with them thinking the roof was leaking through the seams somehow. The rep took one look and told them the problem was that they didn't put insulation in when the roof was installed and they would not do anything about it. The installer was forced to put all new metal on the building with insulation. It was his very first job of that kind that he had ever done. Needless to say, he was upset that the manfacturer failed to tell them that it had to be insulated when you put the steel down before the seams were sealed with the machine. They just sold him the metal and he installed it. No more leaks since the new roof was installed.
Be sure to ask some one that has a building what they would not do if they ever built one again? what they would do and not do and I bet you will get the same answer.
Just think about this! One little leak and you will have foam on the cars under them. When you use fiberglass with plastic underliner if you get a leak it will dry out and not bunch up. I have had a minor leak near a heater vent outlet and it didn't hurt a thing on the underside of the celling.
I will also point out that the white plastic liner on the underside of the roll type ceiling insulation reflects light much better than the yellowish color of the foam. Your building will also stay cleaner too. I feel it will actually look better inside too. IMO.
Do your homework and I hope you come to the same conclusion.
Pantera
69 L78 Nova 7k mi
73 Pantera
69 Vette B/P SCCA
Old 11-29-2004, 07:05 PM
My ceiling on my other barn is already insulated with the white vinyl lined insulation. To put the vinyl under the side wall means taking the sidewall tin off and that is expensive and a pain in the ass. I want to spray the interior wall with foam insulation and then cover with new tin. You wouldn't even see the foam and it would really seal up the walls.
Old 11-29-2004, 07:32 PM
TimG TimG is offline
Glad you got the Shelby back. You have any good shots of it???? Did Cowles do a good job on it???
