Old 09-12-2003, 12:13 AM
NCGuy68 NCGuy68 is offline
Default Re: '67 Muncie Shifter
So what is this stablizer bar from ??
Kim......looks like you've got a 68-72 Chevelle stabilzer shaft there. Its' 'tip-to-tip' length should measure about 10 1/8" using a straight edge ruler. Let us know if thats the case.
The Chevelle stablizer shaft bracket (on the trans end) is different from Camaro. Althought it will bolt-up and work, they are different. I mention this because the 'repop' bracket currently being sold as Camaro is actually Chevelle.
Craig S.
"I saw Elvis At 1000 Feet"
John Force.
Old 09-12-2003, 04:29 AM
68z302 68z302 is offline
Would anyone have a 67-68 Muncie shifter for parts?
Looking to piece together the Mickey Mouse Reverse Dentent spring assembly.
Specifically need the plastic cup that holds all the grease in & the band of sping steel that holds all the bearings in.(If you've seen one you'll know [img]/ubbthreads/images/graemlins/rolleyes.gif[/img])
Or, does anyone sell a kit for this? haven't seen one. [img]/ubbthreads/images/graemlins/dunno.gif[/img]
Thanks
Rob
Rob
'68Z, original drive train
AS1 AO1 D55 J52 U17 U69 Z28
Old 09-12-2003, 04:34 AM
Craig...I sent you a PM.
Tony...I replyed to your PM. Not sure you got it because this form is not acting right lately.
Contact me at [email protected] if needed.
Craig S.
John Force.
Old 09-12-2003, 11:10 AM
TDW TDW is offline
Craig...I emailed and sent a PM. Don't think PM went through.....Tony
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
Old 09-12-2003, 12:55 PM
Zedder's Avatar
Zedder Zedder is offline
Hi Craig,
Can you ID this one?
Thanks!
Mark
Old 09-12-2003, 08:05 PM
The bar is about 10 1/8 long I knew what it was. Just not sure who it was thanks Kim
Jake is my grandson!!
The bar is about 10 1/8 long I knew what it was. Just not sure who it was. thanks Kim
Old 09-13-2003, 04:27 AM
Hi Craig,
Thanks!
Mark...that is a Muncie SB shifter for 67-8 Camaro which is missing the shifter mounting bracket as well as the stablizer shaft and its bracket.
Craig S.
John Force.
Old 09-13-2003, 02:07 PM
JoeC JoeC is offline
Craig, are you sure 67 and 68 Camaro shifters are the same? The Muncie trans levers (dogs) in 67 have a short slot and are held on by a stud. In 69 the levers have a long slot and are held on by a bolt. I am not sure about 68 but the Hurst catalog lists one Muncie lever part number for 67 and down and another number for 68 and up. I do not know GM's cut in date of the new lever design but Hurst shows it as 1968.
Old 09-13-2003, 02:38 PM
Zedder's Avatar
Thanks Craig,
That is what I suspected. I have the bracket and stabilizer, they're just not in the pic. I'll email you a pci of another shifter that is supposed to be for a BB, but I can't tell the difference [img]/ubbthreads/images/graemlins/dunno.gif[/img] Thanks for all of your help!
Mark
