Old 10-31-2019, 12:59 AM
L_e_e's Avatar
L_e_e L_e_e is offline
I have the Borla XR-1's on one of mine, a little loud but I like it.
Sorry for the crappy cell phone vid.
The Following User Says Thank You to L_e_e For This Useful Post:
napa68 (11-08-2019)
Old 11-07-2019, 03:06 PM
Do you get a highway drone in the car?
I am either ordering the XR1 or Dynomax Welded Ultraflows
Old 11-06-2019, 06:36 PM
Sounds like a good combo Aaron. Keep us in the loop.
Old 11-06-2019, 06:42 PM
I am sure you have already considered this, but if you wanting more aggressive than an LT-1 camshaft, using "stiffer springs" you are risking lobe failure. You can combat to some extent by using edm lifters, and making sure you use a good high zinc oil.
Still, if I were going stiffer than stock springs, I think I would just go with a roller cam package. Just my .02 cents. Wish you luck either way.
Old 11-07-2019, 02:31 AM
Yes I have - and actually - almost had a catostrophic failure with the LT1 cam due to TOO MUCH ZDDP.
I had foolishly assumed that if one bottle of ZDDP+ was good, then a bottle and a 1/2 would be better insurance -
BOY was I wrong - after 800 miles, the lifters had spalling - but not obvious damage to the cam lobes and it mic-ed out correctly
I do however have more spring pressure than the stock Z28 springs - but not 130-140lbs like the current solid flat tappets want
Old 11-07-2019, 05:08 PM
L_e_e's Avatar
No drone, but I only go about 60mph when on the highway.
I have the Dynomax on a Camaro, which replaced the Flowmaster 40's, it was
a huge improvement.
Old 11-07-2019, 05:41 PM
Which Are louder
Dynomax or Borla and is it a significant dif?
Old 11-07-2019, 06:00 PM
L_e_e's Avatar
Originally Posted by aaronkl84corvett View Post
Which Are louder
The Borla's are louder, the Dynomax also have a deeper tone.
Old 11-08-2019, 03:40 AM
Alot louder?
The XR1dont come in Center/Offset which might present an issue for a 69 Camaro.
Old 11-07-2019, 05:44 PM
NorCam's Avatar
NorCam NorCam is offline
For 10 years now I've been using Hooker Aero Chambers. Best muffler I have ever heard. Quite but measurable at idle and low rpm cruise, and they wake right up when you get on it but its a smooth deep sound like no other. And at highway speeds you can actually have a conversation w/o much of any drone. They flat out rock and I just ordered another set of them.
I had flow-masters on my black nova and there was a heavy drone at any highway speed. Hooker's are way better all the way around. I'm loading a video for you and will post it in a few minutes here.
The Following 2 Users Say Thank You to NorCam For This Useful Post:
jerry455 (11-08-2019), YENKO DEUCE REGISTRY (11-07-2019)
