Old 04-26-2019, 10:31 PM
Enoch Enoch is offline
Banned
67 through 68 Z28 and l79 curved neck thermostat housing mounting bolts. Two sets - excellent original restored pieces. First set long bolt has CP head marking short bolt is NAT. Second set has the (**SOLD SBC (SOLD**) for the long bolt and M for the short bolt. $40 a set. (X)
Old 04-26-2019, 10:51 PM
Banned
67 through 72 327 350 short water pump, left-hand side alternator mounting hardware. The long lower pivot bolt is SBC for its head marking; the short bolt that attaches the bracket to the exhaust manifold has SB for its head marking and the top pivot bolt has WB for its head marking. All excellent original restored pieces. $50. (X)
Old 05-13-2019, 09:18 PM
Banned
1970 - up hood slide safety catch bolts. Excellent original bolts anchor head marking. These go on the top rear of the firewall Cowl to catch the hood in a front-end collision. $45 PP FF
Old 05-14-2019, 01:23 AM
Banned
Hi performance small block balancer bolt (with safety wire hole) tr headmarking and ss stamped thick flat washer. EXCELLENT CONDITION SOLD $60 shipped to the lower 48 ppff SOLD
Old 05-14-2019, 02:52 AM
302moz 302moz is offline
Default Z/28 crank bolt
I will take the z crank bolt and washer. Thanks
The Following User Says Thank You to 302moz For This Useful Post:
Enoch (05-14-2019)
Old 04-26-2019, 11:17 PM
Banned
67 and 68 Z28 top alternator mounting bolts. These bolts are longer because of the extra brace used in this application. Each set comes with correct lock washer and an NOS thick oversized flat washer. Head markings include SBC, CH, SB, TR, RSC and UR. $30 a set.
Old 04-29-2019, 03:32 AM
Banned
68-69 Rally Sport Camaro headlight door actuator pins. All four have D stamping on them. $40.
Old 04-29-2019, 03:37 AM
Banned
69 Camaro Deluxe rear bumper guard mounting hardware.
The two cadmium plated sems head marking bolts attach the guards to the bumper, the two number 23 bolts attach the guards to the lower Valance and the six C stamped steel nuts attach the inserts to the guards. $80
Old 04-30-2019, 01:44 AM
Banned
67 - 69 four Speed speedometer cable to firewall butterfly clip. When's a last time you seen a real one. This one still has all of its original plating and the butterflies are in perfect condition. You won't find the nicer one. SOLD $150 SOLD
Old 04-30-2019, 01:48 AM
Banned
69 Camaro front disc brake line to upper a arm hose clips. These guys look like they were stamped yesterday, they're that nice. C stamped. SOLD $100 SOLD
