Old 02-05-2019, 03:29 PM
I have tried Vinegar with varying degrees of success. Maybe I was not using it correctly as I was not that impressed with the results.
Old 02-05-2019, 05:19 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Interesting. I didn't do anything special. Highest acidity I could get my hands on and fill the tank. Slosh it around real well, let it sit. Empty and repeat until clean then rinse. When I say the tank was rusty, I've never seen one as bad as that one was.
Glad your block ended up coming out nice regardless of the process!
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
Old 02-05-2019, 06:48 PM
I just wish the deck with the stampings had been in better shape but I guess I will take it over not having it at all.
Old 02-06-2019, 09:59 AM
HawkX66's Avatar
Exactly. That's the best way to look at it. I know a lot of guys wish they had that for a problem.
-Dave
Semper Fi!
Old 02-08-2019, 05:29 PM
Hawkeye's Avatar
Hawkeye Hawkeye is offline
Did the shot blasting have any effect on the broach marks? If you had to do it over again would you have still covered the front pad?
Marty
Old 02-08-2019, 07:51 PM
frankk frankk is offline
Hawkeye where do you find the higher acidity vinegar? Have you used just the food store vinegar?
Old 02-08-2019, 07:57 PM
marxjunk marxjunk is offline
feed stores carry higher acidity..
grainger has 30%
walmart, tractor supply, amazon target etc list it as high acid, but like 10%
this place has it at 30%
https://www.factorydirectvinegar.com...ant=1846487555
i use it alot to do bolts and hardware in my tumbler with the green pyramid product
95% vinegar..5% dawn dish soap..+/-......(specifically dawn) and it does amazing things
Mark
The Following User Says Thank You to marxjunk For This Useful Post:
HawkX66 (02-12-2019)
  #38
Old 02-08-2019, 08:08 PM
Thank you sir
Old 02-08-2019, 09:26 PM
Hawkeye's Avatar
Thank you for the vinegar information.
Old 09-27-2025, 08:16 PM
Tuna Joe Tuna Joe is offline
Originally Posted by L_e_e View Post
I built a couple 392 Hemi's a few years ago and had the blocks shot blasted and they came out looking like new, the factory number stamps remained unaffected.
The lifter valley looks a little shiny as it was slightly smoothed before blasting.
Lee, that looks amazing. You weren’t worried it would damage the vin stamp?
I also like the Evaporust method. Except instead of buying such a large volume of Evaporust, I think I would try and use the heavy duty industrial plastic bag set in water to compress the Evaporust against the block.
And to be clear, shot peening is where the block is secured in an enclosed machine where it rotates the block around with small bb’s?
The Following User Says Thank You to Tuna Joe For This Useful Post:
L_e_e (09-28-2025)
