Old 05-09-2017, 04:54 PM
L78steve L78steve is offline
Originally Posted by cook_dw View Post
Steve I will almost bet you wont be able to use those with the linkage..
Me to Darrell. But if no go I'll try to re-invent the bellcrank. Someone told me ages ago they cut and flipped the BC and made it work.
I figure if there is room for the column shifted auto linkage there is hope.
Old 05-15-2017, 03:20 PM
Well it turns out the backdrive fits without any problems with the Hooker 2205-1 set.
But had interference where I didn't expect it.
The clutch adjustment rod hits the tube and the clutch release bellcrank will have to be modified.
And on the pass side #4 tube is touching the top pivot of the idler arm and will have to be dimpled.
Also the pass header had to be bolted up and the collector bent upward and to the center line of the car. It wouldn't line up with the hump in the cross member and was pointing downward.
Old 05-15-2017, 04:10 PM
bigsixman bigsixman is offline
[QUOTE=L78steve;1353074]Well it turns out the backdrive fits without any problems with the Hooker 2205-1 set.
Also the pass header had to be bolted up and the collector bent upward and to the center line of the car. It wouldn't line up with the hump in the cross member and was pointing downward.[/QUOTE
That's the problem with a lot of current production headers, they do not fit. I would be very disappointed if I had to do all those modifications to get a set of headers to fit a car that they are supposed to fit.
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 05-15-2017, 04:35 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Glad I was wrong on this one..
Sorry the rest didnt work out.
