Old 07-27-2016, 01:06 AM
enio45 enio45 is offline
Default Re: 68 yenko camaro 396 mv suffix engine
same here - heard and read that as well ref the carb
no i do not have the orig carb....ultimately i ended using the L78 carb for my resto
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 07-27-2016, 01:34 PM
Sorry, I don't have my notes with me, the Excalibur Project was the internal GM code name for the prework they were doing in order to accept the L72 COPO request into the '69 Camaros. The rumor was that one of the '68 Yenko Camaros was actually a factory installed 427 car, sort of a Pilot car - has a special plate in the door jamb. IIRC, the car is white, red gut, sold new at Branine Chev in Mulvane or Winfield, KS. However, the rumor and the plate have never been fully confirmed since the Excalibur paperwork doesn't have a VIN on it, but it does indicate something about a carb change and export....
'68 Yenko Camaro with special tag
Old 07-27-2016, 01:53 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Too bad there are no current Hi Res photos
Old 07-27-2016, 03:52 PM
Marlin - thanks for the info - yes forgot about that car......still in kevin's collection?
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 07-27-2016, 04:47 PM
Yes, Kevin still owns that car as far as I know.
Old 07-28-2016, 03:49 PM
JoeC JoeC is offline
There are a lot of unanswered questions on the 1968 Yenkos
The Magic Mirror tag was a standard Chevy tag used on many cars before 1968.
It was not just an export tag. It was used on special order 1968 Camaros including Yenko COPO9737, used on some export 68 Camaros, and used on some non Yenko, non export Special Order 68 Camaros.
I think there were special steps taken by Chevy and Don Yenko make the 1968 427 Camaro legal for NHRA Super Stock. If it were accepted , they would have had to prove that 50 were built and the MV code would prove there were special COPOs built along with a vin list from Yenko.
There are a few surviving documents between Chevy, NHRA, and Yenko, showing the attempt to get the 68s approved.
Old 07-29-2016, 03:39 PM
rjpgh rjpgh is offline
I finally got the MV motor apart and here are some numbers:
crank 6223
cam is solid lifter with only "J" stamped on the end
pistons are domed #3881456 (hard to see)
main bearing caps have cast number of 964
took off main cap #2 and bearing was marked GMM420 324E7 0006
rods are "bump" rods with 3/8 bolts
pushrods are 3/8 diameter
cam sprocket 3856356 with nylon teeth ring
dampener 880 060 GM13
oil filter mounting flange (canister type) 3915164
bores are pristine with absolutely no ridge and measure 4.092 to 4.094
engine internals look very good, probably since the car it came out of sat for many years.
Old 07-29-2016, 06:42 PM
What is the bore ?
Old 07-29-2016, 06:47 PM
cook_dw's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Charley Lillard</div><div class="ubbcode-body">What is the bore ? </div></div>
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: rjpgh</div><div class="ubbcode-body">
</div></div>
Old 07-30-2016, 12:28 AM
the bores are the cylinder diameters (4.092 to 4.094)
