Old 04-29-2016, 05:06 PM
Default Re: Sleeper Chassis Project
Delete...
Old 04-29-2016, 07:18 PM
earntaz earntaz is offline
That goes right along with >> There's never enough time to do it right the first time ... but there's enough time to do it over!!
Old 04-30-2016, 04:44 PM
Delete...
Old 04-30-2016, 04:55 PM
Delete...
Old 04-30-2016, 11:37 PM
Delete...
Old 05-03-2016, 05:18 PM
delete...
Old 05-09-2016, 02:59 PM
Crossbreed383 Crossbreed383 is offline
Have you actually done any measuring to see if a carbed LS will fit under a stock Nova hood?
I can tell you a dual plane Gm manifold, on a aluminum Ls3 ,mounted as low as possible( aftermarket shallow front sump area almost touching frame) , using custom engine mounts, along with a L88 drop base air cleaner just barely fit under hood.
There was zero room for any sort of spacer and you needed to run a very short air filter element as well
Amazingly, a BB Chevy in the same chassis, a RPM Airgap, with a 1/2 Nos plate and drop base filter, fits with room to spare!
Good luck
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
Old 05-09-2016, 03:20 PM
Flat hoods RULE!!
Old 05-09-2016, 05:01 PM
Delete...
Old 05-09-2016, 05:55 PM
Delete...
