Old 10-27-2015, 01:02 AM
Default Re: Horsepower for 69Z 302 w/#140 cam
Cam specs:
140 lash, .024 and .026, duration at lash point: 316 I and 323 E. At .050 lift 243 I 254 E.
178 lash, .024 and .030 (more than I remembered) duration at lash point: .307 I .319 E. At .050 lift, 229 I, 237 E.
Old 10-27-2015, 01:21 AM
Send your distributor to MacNeish or Chevy Ray in that OK, Texas area. Then just drop it in.
Old 10-27-2015, 03:23 AM
miket1 miket1 is offline
[[email protected]]How does the 140 cam effect lifter noise compared to the 30-30? Just wondering.
The 140 from Howards Cams calls for .022/.022, its not as noisy as the .030/.030, after 1 hour of break in running it sounds pretty nice.
69 Z28 Burgandy
Old 10-27-2015, 03:38 AM
Does the 140 cam really perform much better than stock?
Old 10-27-2015, 12:39 PM
earntaz earntaz is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: miket1</div><div class="ubbcode-body">[[email protected]]How does the 140 cam effect lifter noise compared to the 30-30? Just wondering.
The 140 from Howards Cams calls for .022/.022, its not as noisy as the .030/.030, after 1 hour of break in running it sounds pretty nice. </div></div>
That &quot;clatter&quot; is music to a gear head! TAZ
Old 10-27-2015, 02:41 PM
I would think the best benefit of the 140 cam would be with Headers, 2-1/2&quot; exhaust, a little head work, and a steeper gear. This would help the high rpm breathing. With stock exhaust and manifolds, the engine would be choked right when the cam is starting to make some power.
Paul
Old 10-27-2015, 06:53 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: [email protected]</div><div class="ubbcode-body">Does the 140 cam really perform much better than stock? </div></div>
Sam, I have not driven it yet so I dont know, still up on jack stands breaking it in, tuning, etc.
You can hear the solid lifters working but not a loud as the .030/.030 cam .
I had forgotten I had a 6.5 power valve in the carb., installed a 2.5 and it helped smooth out the idle .
69 Z28 Burgandy
Old 10-27-2015, 08:56 PM
the 140 cam will probably be at a disadvantage with the smog and cast iron manifolds. car looks good though!
Old 10-28-2015, 03:30 AM
Car is looking good Mike. I know it has been a long time coming.
Old 10-28-2015, 04:37 AM
Mike,
I see you bought your Z from original owner Dan. Saw this car at our 69 Z/28 display back in 08, was pretty nice then. I see you have the front clip off, are you doing a total resto on this car??
