Old 04-18-2016, 03:55 PM
JRC99's Avatar
JRC99 JRC99 is offline
Default Re: Grandfather's 67 SS Chevelle.
Sent it off to get fixed a few minutes ago.
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 04-22-2016, 08:40 PM
JRC99's Avatar
Dad and I drove it home today. Running really badly (I think it's on 7 cylinders) and the front tires rub pretty bad, despite being the exact same size they've always been.
Also:
1995 Ford F-150 XL
Old 04-23-2016, 06:40 PM
scuncio's Avatar
scuncio scuncio is offline
Make your mechanic fix it...why would you accept it like that?
Old 04-23-2016, 09:23 PM
JRC99's Avatar
We only wanted him to fix the oil pan. Plus we already knew it needed a tune up and would rather do it ourselves.
Also:
1995 Ford F-150 XL
Old 04-23-2016, 09:24 PM
BTL BTL is offline
How did it run before it got towed to him?
Old 04-23-2016, 09:53 PM
JRC99's Avatar
Exactly the same. I trust him, my grandfather's taken his cars there for years.
Also:
1995 Ford F-150 XL
Old 04-24-2016, 01:41 AM
Are the front springs sagging or do you need a narrower tire?
Old 04-24-2016, 01:54 AM
JRC99's Avatar
I'm not sure. I know it's not the tire, as it's the exact same size as it was before and they never rubbed. My theory is probably incorrect, but I feel like the rake it has made the front lean down a bit if that makes sense. Almost like weight transfer. Probably wrong though.
Also:
1995 Ford F-150 XL
Old 04-24-2016, 11:08 AM
My old big block 1968 Camaro SS had a similar problem when I owned it; had to replace the original front coils to correct the tire rub problem.
Old 04-24-2016, 11:52 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JRC99</div><div class="ubbcode-body">I'm not sure. I know it's not the tire, as it's the exact same size as it was before and they never rubbed. My theory is probably incorrect, but I feel like the rake it has made the front lean down a bit if that makes sense. Almost like weight transfer. Probably wrong though. </div></div>
Actually I was going to suggest the very same explanation since the problem started after you added the bigger rear tires.
