Old 10-31-2010, 02:58 AM
Default Re: 1959 Bel Air Winter Project
You give it an LS9 and it will FLY!
Old 10-31-2010, 03:13 AM
napa68's Avatar
napa68 napa68 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JK98SS</div><div class="ubbcode-body">I talked to a guy today. He has several exhaust parts around with those flanges. He said he would sell them cheap if you need some. He said they are different on some years and would need to know the year and car your engine came out of. </div></div>
Hey, I appreciate the lead! I had gotten quite a bit cleaned up today in the engine compartment, installed the new trans crossmember, the new engine stands (frame to mount),removed the wiring harness,and installed the conversion mounts of the LS1. With some luck, perhaps I will have a chance to do the first trial of setting the engine in this week. I've got another slug of pictures for you guys that I will try to get posted tomorrow.
Tim
Old 10-31-2010, 04:10 AM
kwhizz kwhizz is offline
Do you have the ECM and the trans computer??
Ken
Old 10-31-2010, 04:23 AM
napa68's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body"> Do you have the ECM and the trans computer??
Ken </div></div>
Yes I do. At this point (driven by many suggestions) I am not sure if I should use that or just purchase an entire aftermarket harness and computer. Suggestions anyone?
Old 10-31-2010, 04:28 AM
Call John at Speartech............The guys here only know about Points and Carbs........
Oxygen Sensor Guy......
Old 11-01-2010, 02:25 AM
napa68's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: napa68</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: scuncio</div><div class="ubbcode-body">Cool project. Will be interesting to see how much cutting the Air Ride kit requires. </div></div>
The Air Ride is in!. The tank and compressor are mounted underneath on each side of the fuel tank. This all was installed by the previous owner. He plumbed it with hydraulic hose rather than nylon for durability. I'll take some close up photos tonight or tomorrow. </div></div>
Here are the photos as promised on the Air Ride components.
I posted a couple of pictures of the engine compartment. Would you guys leave it or refinish it? My buddy from Rad Rides was all over me to refinish it. Of course in the next breath he mentions an Art Morrison chassis to me! [img]<<GRAEMLIN_URL>>/sick.gif[/img] Hopefully tomorrow or Tuesday, I am going to set the engine and trans in to see how this all will work with the accessories, manifolds, ECM etc. I can make some decisions from there.
Old 11-01-2010, 02:31 AM
427TJ's Avatar
427TJ 427TJ is offline
I like the idea of a modern driveline and 50-year patina everywhere else. Put the LS in and then later if you decide to refinish the engine compartment you can.
Old 11-01-2010, 05:19 AM
Man .......That car has lived a very protected life........As rust free as they come.......Now!!........Pack all those wires hanging from the hoist and ship them to Speartech.....If you need any help with anything, just let me know....
Sensor Guy
Old 11-01-2010, 11:10 PM
x  Baldwin  Motion's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 427TJ</div><div class="ubbcode-body">I like the idea of a modern driveline and 50-year patina everywhere else. Put the LS in and then later if you decide to refinish the engine compartment you can. </div></div>
yeah, I'm on this page too. It's only original once AND it looks too good to mess with. [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Old 11-03-2010, 04:43 AM
napa68's Avatar
For tonight's work, I dropped the motor in to see how everything fits. While you would think it should be a slam dunk, I did run into a few items that can be taken care of.
The right side manifold is a litte tight, but will work
The left side though, the O2 interferes with the frame and the casting is real close to the mount for the lower control arm. I should be able to use the manifold, I will just have to move the O2 into the pipe.
The oil pan hit just a little on the left side right on top of the crossmember. The spacing behind the crossmember is pretty much spot on.
Nice amount of room behind the engine although the brake booster is going to be a little tight.
The spacing for both the engine mounts and the trans crossmember were spot on!
Looks like I will have to use an aftermarket accessory drive. I am doubtful how much O.E. accessory equipment I can use. I do like how compact the units from Vintage Air and Billet Specialties are packaged. Just a little more than I wanted to spend.
Thats all for tonight!
Tim
