Old 05-14-2010, 05:06 PM
1966L72 1966L72 is offline
Default Re: 1969 Z28 Restoration
Thank you, these pictures are very helpful, I can now see why the blue overspray appeared gray, I would never have thought to use gray primer over the black yet under overspray color.
1970 Chevelle LS6
1969 Camaro Z28
Old 05-15-2010, 03:07 AM
firstgenaddict's Avatar
Not until looking at unrestored cars would I have ever thought of it either...
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 05-15-2010, 03:26 AM
The Original Sub frame bolts and Washer set ups, this is being discussed on the CRG as well as it seems the expensive repro's are not correct.
Original front sub frame to body mounting bolt assembly (68 and EARLY 69... change in the AIM is Sept.
RBW BOLT - lock washer - Spring washer (silver) - Flat Washer which appears to be heat treated steel.
The undercoating was shot at an almost perpendicular angle to the bolt head from about 9. The swath on the back was blocked from the undercoating and subsequently rusted.
The cupped washer was covered however after flexing during removal it flaked off easily.
RAD MOUNT BOLTS - LEFT REPRO RIGHT ORIGINAL
Chambered Exhaust retainer
Original rear fuel line bracket
Original molding clips... they are nice enough to reuse... lol
~JAG~
NCRS#65120
Old 07-10-2010, 09:03 AM
Few More
Drivers BRAKE CALIPER DATED 240th Day of year (exactly as one would expect for an Oct built car)
A-arms and other brackets were DIPPED as from the factory (note runs)
Rear Brakes, all repro springs were wrong colors, mixed from originals and painted
Axle Cast date I308
AXLE Assembly code
BV 10 31
Floor Pan Plug and bottom of floor
~JAG~
NCRS#65120
Old 07-10-2010, 09:05 AM
Inside floors and inner doors
Original Dated Floor Pan Plugs
Sealer for Floor pans & another Floor Plug
More Component Details
Steering Column
~JAG~
NCRS#65120
Old 07-10-2010, 04:57 PM
Man James, that car is looking great!
Old 07-10-2010, 06:04 PM
mockingbird812's Avatar
James - VERY, VERY nice attention to detail. Love your history [img]<<GRAEMLIN_URL>>/scholar.gif[/img] lesson here. Keep your photo chronology coming. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Sam...
Old 07-10-2010, 07:02 PM
69z28302 69z28302 is offline
Is that a Kentucky plate on the car? Just curious.
Mike
Old 07-10-2010, 08:00 PM
scuncio's Avatar
scuncio scuncio is offline
No, it's a 1973 Michigan plate (the car was from the Flushing, MI area).
Old 07-11-2010, 07:07 PM
How's that Monaco Orange <span style="font-style: italic">stripper</span> Chevelle coming along Tony?
~JAG~
NCRS#65120
