Old 10-01-2009, 06:16 PM
JRSully JRSully is offline
Default Re: Engine block stampings
A CE L78 block won't have a specific vehicle VIN stamp on it, just an assembly date and or serial #
71 Porsche 911 Targa
Old 10-01-2009, 07:04 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Sometimes the VIN# is very, very hard to make out. Make sure that you remove all of the paint and take a picture of the stamp area with a good camera. Crop the picture and blow it up as big as possible. I had to do this with my Pace Car #272 block. I could just make out partial impressions of enough of the charactors to verify the vin.
So are you saying that CE blocks have the VIN stamped on them??
Old 10-01-2009, 08:12 PM
PeteLeathersac's Avatar
Not specific to any engine applications in particular but depending on what GM had on hand the over the counter and/or warranty replacement engines were sometimes supplied in CE or suffixed applications..
Consider the genuine Suffixed but non Vin stamped Corvette blocks/engines that are floating around as an example..
On CE's w/ Vin stamps, not that they often/ever did it but wasn't the General's policy instructions to the dealer installing a warranty unit to stamp the Vin into the replacement unit?.
~ Pete
Old 10-01-2009, 09:16 PM
ssl78 ssl78 is offline
The way I understand it if wasnt a complete motor the block recieved a ce, if you bought a complete motor it normally had the normal engine build date and suffix. Example is the 1970 Harrell Camaro that just sold had I believe a CRV code, since it started off as a small block car it recieved a complete motor.
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
Old 10-01-2009, 09:31 PM
turbojet427 turbojet427 is offline
Yenko Advertising Member
I can not see a VIN # anywhere on my DZ short block. The short block has very little useage and has never been disassembled. I was just curious if it could of been a crate motor or was it in a car and no VIN # stamped. MY CE 1970 L78 motor has no VIN # and I believe CE motors never did.
Old 10-01-2009, 09:34 PM
DarrenX33's Avatar
My Z has the VIN on the oil filter flange but is barely noticable. Took a while to find it as well.
1969 Z28
1972 Corvette
Old 10-01-2009, 10:10 PM
My 70 Z engine was assembled in Flint and deck stamped V0729CTB.
I bought this car in 78' from Original owner
What is very unusual (I would think) is that the VIN 01N5xxxxx is NOT stamped in the normal bellhousing flange area.
I found the VIN # stamped in rough cast material roughly between the left side soft plugs....
Has anybody ever seen something similar on a FLINT small block.
Does anybody challange my assertion as being phoney, restamped or otherwise forged ?????
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
