Old 06-10-2013, 03:41 AM
x77-69z28's Avatar
Default Re: Chevelle updates
Oh baby!
Old 05-20-2014, 12:42 PM
VintageMusclecar's Avatar
Not much of an update, but FWIW;
It's been almost two years since I last had the Chevelle out. A few weeks ago I drained the stale fuel and added ~10 gallons of fresh fuel. I also finally diagnosed a mystery charging issue that turned out to be a new (well, new when I was building the car) but toast voltage regulator.
After numerous failed attempts (for a variety of reasons which I'll spare you from reading) to get the car out since then, I finally managed to get the car out yesterday for a short drive.
I made it all of two blocks before the shifter jammed in neutral with the trans stuck in 2nd. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
I limped it back home and waited for the exhaust to cool down enough to crawl under the car.
Once I'm under the car, I jiggle the shifter arms and pop the box back into neutral. I grab my trusty HURST 1/4&quot; shifter alignment pin and with minimal coercion it slid right in. [img]<<GRAEMLIN_URL>>/dunno.gif[/img]
Back out of the garage and down the road again for attempt #2. I only had time to drive a couple of miles, but it sure felt good being behind the wheel again.
I have numerous updates awaiting for the Chevelle and several other projects to announce as well, but right now, &quot;free&quot; time is a commodity I have precious little of. I'm trying to find a way to make things happen, but for now I'm at the mercy of others.
More eventually.
Old 05-20-2014, 04:55 PM
427TJ's Avatar
427TJ 427TJ is offline
Eric, I would be happy to fly in and exercise the Chevelle for you.
Old 06-28-2014, 12:34 AM
A few weeks ago I managed to find the time to get some work done again on the Chevelle.
When I built the 496 back in 2008, I tried something I'd never done before with the ring package that didn't quite pan out as I'd hoped. After the last drive I decided it was past time to do something about it, so the 496 came back out. (note: this is why I test these things out on my own stuff, not a customers engine)
Side-note: I also REALLY wanted to get that 621 bellhousing out of the car. In it's place will be a Quicktime scattershield and block plate.
The engine came down and was re-honed, and while I was at it I swapped in a set of new custom Autotec pistons to drop the compression down from 11.2-1 to 10.5-1. (The Autotec pistons also feature a much nicer modern ring package) This will give me a bigger tuning &quot;window&quot; so I can see what (if anything) there is to be had with more aggressive tuning.
Everything else remains the same from the previous build, noting the addition of the Stef's oil pan I installed after the engine came off the dyno the first time.
I dropped the engine &amp; peripherals off @ Kammers today, the tentative plan is to test some time next week if/when this heat breaks a little (hoping for Wednesday/Thursday).
I was planning a pretty extensive series of tests this time around, but the situation on the home front dictates otherwise--even with my now abbreviated itinerary, I'm still probably looking at two days on the dyno to cover the bases I can.
Note that I'll be using 100 octane LL Avgas as the baseline fuel.
Here's some of the planned tests (in no particular order):
1) Re-establish a new baseline with the engine as it was last in the car/on the dyno save for the change in pistons/rings and the Stef's oil pan.
2) Header test: The existing headers are Hedmans with a 2&quot; primary and 3&quot; collector. Once the new baseline has been established, I will remove the 3&quot; collectors and install a pair of 3 1/2&quot; Schoenfeld collectors. If time allows, I'm also looking to test with a set of 2 1/8&quot; and 2 1/4&quot; headers if Kammers has suitable pipes available.
3) Lash, timing &amp; Jetting loops: I wanted to do this when I had the engine on the dyno the first time, but we ran out of time to get it done. Depending on the outcome of the timing loop testing, I *may* test between 100 octane LL (Avgas) and premium unleaded pump fuel. If the engine wants 38°-40°+ for total timing, I'm not going to bother as I know it won't tolerate the pump gas with that much timing.
4) Spark plug test between non-projected tip and projected tip. (same heat range NGK's)
5) Carburetor test between the 3418 OEM vacuum secondary 855 cfm carb and a conventional Holley LIST 4781 850 cfm double pumper.
6) Ignition test: The engine will be baselined with the OEM points distributor and coil and will NOT utilize the MSD box on the dyno. Afterwards I will install a MSD billet distributor and we will hook up the 7AL unit on the dyno to see what (if anything) is there.
7) Air cleaner test, with and w/o.
8) Intake manifold test: The engine will be re-baselined with the 163 intake with the cut plenum divider. Afterwards I will install a heavily modified Holley Strip Dominator intake (which is destined for another project to be announced later). Next, I will install my Edelbrock UR2X tunnel ram intake and 4779 750 cfm double pumper carbs.
Some of the other things I'd planned to test if time allowed:
A: Move the cam from a 105° ICL to 109° in an attempt to trade some low/mid power for upper rpm power
B: Oil pan test between the Stef's unit and a Milodon 31188 pan.
C: Rocker arm test between 1.7 and 1.8 ratios
D: Testing the baseline 163 with the cut plenum against a <span style="font-weight: bold"><span style="text-decoration: underline">heavily</span></span> ported 163 I have.
FWIW, this will most likely be the &quot;last hurrah&quot; for the Chevelle, at least while it's in my possession.
I'll post the results in a new thread in my forum and link to it in this thread.
Old 06-28-2014, 01:16 AM
mockingbird812's Avatar
Can't wait Eric!!!!
Sam...
Old 06-28-2014, 05:57 PM
69 Post Sedan's Avatar
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 06-30-2014, 07:40 PM
Just got the call from Bob, the engine's on the dyno and ready to fire.
I'll be out there first thing tomorrow morning.
Old 07-01-2014, 11:40 PM
Preliminary reports are in, but data is yet to be posted.
Click here
Old 07-04-2014, 04:58 PM
Final results are in.
Click here
Old 08-19-2014, 11:03 PM
I’ve been working out the last few bugs on the Chevelle and I have it pretty close to dialed in, there's still just a tiny bit of part-throttle carb tuning to reel in.
Yesterday I received a new Crane Xr-i ignition module to replace the one I popped back in `06 when I installed the engine in the car--it really helps if you wire them up correctly. [img]<<GRAEMLIN_URL>>/rolleyes.gif[/img]
I've also been busy making a home-made advance limiter bushing for the distributor that would allow me to bump up the initial timing a bit w/o having too much total.
Anyhow, yesterday I managed to get both items installed. The Crane module really cleaned up the idle (along with the extra few degrees of initial as well) and improved the throttle response. I also got my digital speedometer/e.t. calculator calibrated yesterday, and I made a slight adjustment to the tire pressure on the L60’s.
I took it out today for a few laps around the block, and a brief “clear its throat out” romp (just through 1st gear and a quick shift into 2nd).
Two things to note:
1) The reduced pressure made a major difference in traction—it didn’t roll them over anywhere nearly as bad as it did before—as a matter of fact, I thought my head was going to wind up in the package tray for a moment....) I can’t believe those things hooked as well as they did. I’m honestly impressed with those tires.
2) Putting it bluntly...this thing’s stupid. [img]<<GRAEMLIN_URL>>/naughty.gif[/img]
This is w/o a doubt my all-time favorite build I’ve ever done for myself, and it almost scares me to think that there’s still quite a bit of un-tapped power still waiting in the wings.
I really need to get that 4.56 gear out of there though, it’s total over-kill on this car. A 3.73-4.10 gear would be perfect for it.
If I can somehow manage to pull it off, I'll try to get a ride-along video done before too long and post it up.
